Question about Compaq Presario CQ60-204NR Notebook
Why won't cds play in the dvd-rw?
Everytime ai put cd in dvd-rw drive it does not read
  • max carson
    max carson Nov 01, 2012
    What kind of CDs?
    Scholar:
  • 106 Answers
Nathaniel, DVD RW have the capability of playing any CD. If you are facing problem then either:
a) Your CD is not right or has too much scratches on it.
b) Your DVD RW Lens has gotten a bit weak. Clean your DVD RW lens and then give it a try.
Posted on Nov 01, 2012
SOURCE: PIONEER DVD-RW READS ONLY DVD BUT NOT CD
buy a HP
Posted on Feb 08, 2008
geokohler
  • 304 Answers
SOURCE: Replacing CD-RW/DVD Drive
I own a Presario F730US. I have had it apart many times and it is a difficult case to open. There are several ribbon cables that are easily damaged if you are not very careful. You have to pop up the speaker cover panel as there are case screws under it as well. Once inside you will see the screws that retain the optical drive. Once you remove them it will slide right out and the new one will slide right in. I can not overstate how careful you have to be. If you are not 100% sure of yourself I would recomend that you take it to a repair shop and let a qualified tech assist you. The screws you need to get to are under the keyboard. The whole laptop does not need to be disassembled to swap the drive. Once you pop the speaker bazel and the keyboard you are home free. If you need more help feel free to ask.
George
Posted on Aug 04, 2008
LaptopExpert
  • 458 Answers
SOURCE: My presario R3000's combo drive no longer wants to burn dvds
Try a different Brand Of DVD Maxell Typically Work Universally With Failing Drives or older Drives or touchy drives...
Posted on Nov 17, 2008
  • 94 Answers
SOURCE: My Dual Layer DVD±RW for my presario v2410us will not read CDs
It happens in combo drives where the cd reading wont work and still read or burn dvd's or vice versa. If you tried to use a cd cleaner and still didnt work then the cd reader is already busted. it either you replace it a new one or not.
Posted on Aug 01, 2009
SOURCE: optiarc dvd rw ad-7560A ATA device won't play cd or DVD
http://support.microsoft.com/gp/cd_dvd_drive_problems
Posted on Jan 01, 2010
Cds wont play in dvd-rw player
The only discs that a DVD player is guaranteed to read are DVD discs. Support for CD-ROM, CD-R, and CD-RW may be included, but is by no means guaranteed.
CD-R was designed to be read by an infrared 780nm laser. DVD uses a visible red 635nm or 650nm laser, which aren't reflected sufficiently by the organic dye polymers used in CD-R media. As a result, many DVD players can't read CD-R media. Some DVD players come with two lasers so that they can read CD-R.
But as I have already stated that Most DVDs today have the tendency of playing CDs. So if your DVD player is new then it must have that support. Have a look at the quality of your CDs also.
Oct 31, 2012 | HP Compaq Presario CQ60-249US Notebook
My cd drive will read cds but wont read as a burner
Not all Inspirons have CD burners (the 4 factory options were CD-ROM, CD-RW, DVD-ROM, and DVD/CD-RW. You can confirm that via Windows Start > Control Panel > System > Hardware > Device Manager and double click on DVD/CD-ROM drives to see what model drive you have, then just Google it to see what it's capable of.
In case you have either a CD-RW type drive or a DVD/ CD-RW drive and it doesn't want to burn CD's , then it's a bad drive.
Sep 08, 2011 | Dell Inspiron 1100 Notebook
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
It doesnt read any dvd neither software nor video, but can read audio cds, vcds, and mp3s
Put a DVD disk into the drive.
Open "My Computer".
Right-mouse click on the icon for the CD/DVD drive.
Click "Explore".
If a window opens, then your hardware can read the DVD media.
If not, then you need to replace the CD/DVD drive.
Then, you need software, such as the _free_ 'VLC' software,
downloadable from the Internet, to play DVD-videos on your computer.
Sep 28, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
My samsungsd616tdvd drive cannot play or read dvd-rw cds.
Please note that the formats of DVD and CD are quite different. Whereas a DVD drive can handle both DVD and CD, a CD drive can only handle cd formats. Furthermore, a drive that reads both formats does not necessarily mean it can handle the writing aspect ok. You need a drive that is capable of writing/burning DVD. Most drives that come along with pcs can only write CDs but able to read both. So check your drive to see whether or not it can write on DVDs ok. Good luck
Apr 29, 2009 | Samsung SD 616T Internal DVD Drive
My DVD/CD-ROM can not read dvds
DVD/CD-RW combo drives are capable of reading the DVD's but cannot burn so try playing a DVD with some content on it also Download VLCPLAYER
if you don't have a DVD player already on your system. As far as CDs are concerned it can both read and write to CDs
Feb 01, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Compaq Presario CQ60-204NR Notebook Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
