Question about Vizio Televison & Video
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
I have a Vizio VU42L-FHDTV10A that won't power up by button or remote. I replaced the power supply board with no luck.No lights come on although I have power into the powerboard. How do I test the High Voltage Transformer? Or, could it be something else? If so, how can I test the other option as well?
  • Dick
    Dick Nov 06, 2012
    Is it possible to tell me where I can locate the 5vdc on the mainboard and the "on" terminal on the power supply board? I've got a multi-tester and can do the test. I just don't know where these points are. If it helps, the mainboard # is 0171-2272-2364 (3642-0112-0150(4A). The powerboard # is DPS-283BP A. Thx.
  • Vizio Master
  • 933 Answers
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Posted on Nov 01, 2012
4 Suggested Answers
  • 41 Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
  • 187 Answers
SOURCE: I want to know how much a Vizio VU42L FHDTV10A screen costs.
The price range is 500-800 depending where you will get it, try Ebay and look for a non-working one with a good panel (screen), it does not matter why is not working as long as the panel is in good condition.
Posted on May 27, 2009
eagle338
  • 4889 Answers
SOURCE: i have a vizio vu42l
There not need not be burn marks when components are shorted. And yes I do think its definitely a case of short in the power supply. I am 100% sure replacing it would resolve the problem.
Posted on Feb 16, 2011
Vizio Vo37L fhdtv10a has no audio or video. Vizio emblem changes color with panel or remote power button. otherwise no response. Don't know whether to suspect panel, T-CON, or main board. Thanks
Chances are you can rule out the tcon if you don't have sound, it could be either the main or power board, if you have a meter you can test the voltages on the power supply and see what is missing and figure out if your getting the signal from the main to turn enable PFC
Dec 02, 2017 | Vizio Televison & Video
I have a vizio gv42l fhdtv10a I have no picture or sound.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 14, 2016 | Vizio GV42L 42 in. LCD Television
How do I change a power supply on a vizio VU42L FHDTV10A
I think if you have to ask how you should not be attempting to do it.
perhaps if you explain why you want to replace it (a guess) I could advise you.
Apr 28, 2012 | Televison & Video
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,
First of all, thank you for posting your question here at Fixya.
Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.
If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.
Hope I helped you.
Have a nice day!
Good luck and take care!
Jdvillanueva
Dec 21, 2011 | Vizio VU42L 42 in. LCD TV
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one
http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
Mar 06, 2011 | Vizio VU42L 42 in. LCD TV
Missing screws for detachable stand for Vizio VU42L FHDTV10A. How can I find replacement screws?
www.searspartsdirect.com ,base screws #4x26 tap part#172100042650 $2.16 there in stock
Sep 22, 2010 | Vizio SV421XVT 42 in. LCD TV
3 y/o Visio VU42L with no pix or sound
well,mike seems youve done everything to your TV and nothing happen..Try to reset the system of your TV.On the main board there is a small button just press it to reset your system and see if your TV will work again tnx.
i hope i help you..
please rate my help...
Jun 06, 2010 | Vizio VU42L 42 in. LCD TV
May 16, 2009 | Televison & Video
VIZIO VU42L FHDTV10A screen goes green sometimes
I need a screen for my vu42l if anyone near Connecticut has one. If not, I have parts from a vu42l.
email mbsimonds AT aol DOT com
Aug 11, 2008 | Televison & Video
Televison & Video Logo
240 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
