Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Rinse water fills the washing machine when the spin cycle starts
The machine goes thru the cycle until it gets to the final spin. The final rinse water starts to pump out, but the machins turns the water fill back on during the drain pumping. Then the machine spins with a load of rinse water in it that can't pump out because the drain pump stopped with the start of the spin.
  • 32 more comments
  • David McCrohan May 18, 2007
    Premm, Please pay attention to the problem before you blurt out a "fixall soluion" that has absoutly no relevance to the situation!
    Again, the water pumps out fine if the feed valve is closed. The machine thinks it is supposed to turn the water on when it does the final spin. WHY DOES IT TRY TO REFILL THE TUB WHEN IT TURNS ON THE PUMP?
  • Anonymous Mar 12, 2014
    On rinse cycle the machine will not rinse and water does not drain.
    machine does not fill on the rinse cycle
  • Anonymous Mar 13, 2014
    The water filled up, the lid was closed and then the washer turned off and now will not turn back on or go through a rinse, spin cycle, and will not drain.
  • Anonymous Mar 14, 2014
    my hoover washing machine start the wash normal, but it does not complete the wash.before it goes into rinse the time saver light comes on and the machine stop turning. I tried to switch to spin or drain but its not working
  • Anonymous Mar 16, 2014
    Machine won't drain from final rinse cycle to then move to drain and spin
  • Anonymous Mar 17, 2014
    Low water on rinse cycle until you reset start/stop knob
  • Anonymous Mar 18, 2014
    Shortly after a wash cycle begins, all indicator lights light up and beep incessantly until a button is pushed. We can bypass it by running a rinse and spin, but this is a constant problem.
    not spinning out water on last rinse
  • Anonymous Mar 19, 2014
    fills up with water but will not start cycle .I can manually turn the timer to engage it in the drain mode turning it passed the wash cycle directly to the rince cycle and it will drain the water out and spin and stop.
  • Anonymous Mar 20, 2014
    WAshibng machine trips RCD when washing, usually at the filling stage. Machine will operate on spin/rinse cycle with no problem. Suspect it is the heater.
    All indicator lights function. A few seconds into cycle (just as water begins to fill) the door lock disengages, the lock indicator light goes out and cycle stops. The door lock assembly seems the obvious problem. Is there a way to determine instead of guessing?
  • Anonymous Mar 21, 2014
    water enter, detergrent goes thru machine, cycle runs but noo movement
  • Anonymous Mar 23, 2014
    my washer operates normally in all other ways, but when I try to use the rinse and spin option it does not fill with water. There is noise but no water enters. The machine cycles, agitates and spins as if it were working but clothes come out as dry as they entered.
    Red light comes on and i've check the filter/pump outlet which has been clear of debris but still no action from Washing machine. Red light flashes then goes constant but no water pumped or spinning at all.
  • Anonymous Mar 24, 2014
    the leds dims off while the water valve in opened
    FINAL RISE PUMP WONT DRAIN WATER OUT
    QWD
  • Anonymous Mar 25, 2014
    Stops at rinse cycle
    Fills at rinse cycle and stops
  • Anonymous Mar 26, 2014
    when we programm for washing and start it rinse the water immediately
  • Anonymous Mar 29, 2014
    The cold water "fill" will not cut off and stop flowing into the machine during either the wash or rinse cycle
    stops during rinse cycle and the water will not drain
    When starting a load of wash water goes out the drain instead of filling up in the drum where clothes are, have to plug the drain hose and then it starts to fill, does in both when starting a load and when starting rinse cycle.
    Where would the pump be and how to change?
    could it be a pump bearing?
  • Anonymous Mar 30, 2014
    water doesn't enter
    Machine fills with water. Completes the wash cycle and drains. It hangs when it gets to the rinse cycle. I can cancel the cycle and switch the machine to the rinse cycle and it will complete.
    WATER DOESN'T DRAIN AND SPIN CYCLE DOESN'T START
    it fills up with water but it will not spin it humms
  • Anonymous Mar 31, 2014
    Note: i tried only giving spin and rinse after getting this problem...it didnt work at all...it produces a weird sound
    machine goes through it's cycle but does not spin.
    machine goes through it's cycle, but does not spin.
  • Anonymous Apr 01, 2014
    the machine washes but does not want to spin, it only spins for 2 mins then starts filling with water.
    President:
  • 1,294 Answers
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
When washer goes into the rinse cycle it won't fill it contue to try and fill but won't
Check your manual. Some washers don't fill when they rinse, instead, they spray rinse. While the tub spins, they spray water in every few seconds until the cycle is completed. This is also how the second rinse works on a lot of models.
Dec 01, 2009 | Whirlpool Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Will not automatically switch from washing spin to rinse.
check to make sure you have both the hot and cold water lines connected and the water is turned on. sometimes the hot or cold line will clog up and it will not fill up during the rinse cycle. the humming sound may be the water valve coming on but no water is coming thru.
if you have a warm rinse set it to that to see if this is the problem.
you can clean the screens on the water valve by taking the water inlet hoses off the machine and you can look at the screens onside.
if not it may be a timer problem.
Jun 26, 2008 | Roper RAB2121KW Top Load Washer
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
1,341 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
