Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven will not light
I have a kemore stove about 10yrs old glow plug comes on but the gas willnot works when it wants to
  • tezcoco28 Jan 09, 2009
    Do you have to turn of gas/power before you change it out?
My oven will not ingnite
Posted on Feb 04, 2009
  • 115 Answers
Change the glow plug it is not drawing enough amps to open the safety gas valve up if you change it I guarantee it will work
Posted on Jan 04, 2009
  • 163 Answers
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
My stove does not light. THe brolier and the burners work fine
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening.
here is a link showing pictures of typical igniters.
http://images.google.com/images?hl=en&q=ge%20oven%20ignitor&um=1&ie=UTF-8&sa=N&tab=wi
If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 18, 2009 | GE JGRP17 Gas Single Oven
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Can I still light an oven even if the electric pilot doesnt work
Looks like your oven has a "glow" coil. That being the case, you will not be able to light the oven without power. It has to glow to open the valve, and there is no override for this. Sorry.
About the cord, you could install a plug on the cord, or simply replace the cord. (I realize you say you are trying to get one). Other than this, turkey on the grill is always good.
Mr Boo
Nov 20, 2008 | Tappan 30IN ELEC IGNa Oven
Double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven fills with gas Maytag Appliance MGR5780BDQ
Your ignitor is becoming defective. Even though it is glowing, it is not creating the proper resistance to "pop" the gas valve open. Instead, gas slowly seeps into the oven cavity until it finally ignites and causes a potentially dangerous situation. Call an experienced technician and have it checked.
Oct 01, 2007 | Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
157 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
