Recuring F1 code while washing - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
A common problem for the f1 code is only a bad connection on the motor position sensor. Tip the washer up and remove the motor magnetic field only one bolt, allen wrench, 4 more 9mm bolts and the motor armature will come out be careful not to let it fall to the floor. You will see a small circuit board with a half dozen or so brown wires going to it, remove the connector and clean the contacts, use a q tip with alcohol. This type of connector loses a good contact over time from vibrations causing low voltage.
Posted on Nov 01, 2012
Recurring F1 code while washing
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
IM GETTING F1
Hello there and thank you for using fixya
Well i wish i had better news for you but your f1 code is teling you that 1 of 2 things are failing.
First is that you electronic range controle has failed and needs to be replaced
Or that your touchpad has stuck and needs to be replaced .
Here is how to test to see which one it is
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
Remove the back panel from the oven controls to expose the controle panel .
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 24, 2011 | Amana AEW3530DD Electric Single Oven
My stove is heating up and blinking F1, what do i do. we have tried to unplug it and it is still doing it.
Hello there:
This error code is due to the controle panel being faulty or the keypad being faulty the best way to find this is as follows
remove the back panel for the controls
Jan 24, 2011 | Kitchen Ranges
Westinghouse LT819S 1F error and beep.
hello there
This is a verry common issue with these ovens
Here is the meaning and a few things to determine what is at fault i have it listed below
this error code can actually show up as any 1 of these and they all mean the same thing
F0 -
F1 - F7 Stuck keypad
may mean relay is turned on.or has
failed
Jan 21, 2011 | Kitchen Ranges
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Error Codes F0 and F7 on G.E. Wall Oven
F0 , F1 , F7 - Stuck keypad may mean relay is turned on.
You could have a Tech Sheet from :-
http://www.repairclinic.com/0078.asp
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | GE Ovens
What does code F1 mean?
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Jan 04, 2010 | Kenmore 41389 Electric Double Oven
Caloric gas range problem
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Dec 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Control panel shows F7 and contantly alarming or beebing
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
