Question about Gateway Computers & Internet
Upgrade video card for gateway SX2855 UB22 - Gateway Computers & Internet
shadow5599
  • 51 Answers
SOURCE: Video card upgrade
Relevant link
Yes it does have an AGP slot, which you can confirm easily by looking at the motherboard. The AGP slot would be found at the top of the available slots and is brownish in color and slight smaller than the several white PCI slots.
As for what card to put in, that depends on your budget and needs.
If you're a gamer, spend as much as you can and go with a N-Vidia based AGP card.
Please rate this as solved once you've read it, unless you have further questions, then post another comment.
Thanks!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Posted on Oct 18, 2007
  • 123 Answers
SOURCE: Upgrade video card
Any of the cards here are suitabl,e with almost all under $100 and are all PCI Express x 16
Your mobo is not suitable for the PCI X 2.0
Remember the amount of memory on the video card comes from your available ram - so you need to consider this when buying if you dont have much ram.
If you need more help deciding let me know
Posted on Apr 20, 2009
  • 13433 Answers
SOURCE: I need to upgrade the video card for my Gateway 7330GZ laptop
Hey,
looked over the spesifications of your laptop, the video card thats build into the laptop doesn't have pixel shader 2 support and it can't be replaced since its build into the motherboard.
noting you can do about it, other than buy a newer laptop with a better video card, almost any ati or nvidia card will do, if your going to buy one you can check in with me and I'll make sure its got what it needs to run the game or you can ask the sales people to check on it before you purchase it.
Thanks,
Ekse
Posted on Jun 08, 2009
  • 16 Answers
SOURCE: best video card upgrade for Gateway GT4024????
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Posted on Jun 10, 2009
  • 5387 Answers
SOURCE: Would like to upgrade Gateway Desk Top 500SE to a HD video
I don't think you can't do that without some major changes. The 500SE is a small format computer. The motherboard only has 2 PCI slots so you need to match that interface. NewEgg still sells the PCI video cards but I don't think they are HD
http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=48&Description=&Type=&N=2010380048+1069609642&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=696%3A9642
You need a more larger power supply. The current one is a 145 watt u-ATX Form Factor; you need at least 250 watts in that form factor (size)
A better choice might be a new motherboard. Look for board with a AMD Socket 7 if you want to keep this CPU. The motherboard will need to match the size of the current one to reuse the case. It's a uATX "like" form factor (7.4" x 9.35"). Also plan on a new power supply any AGP or PCI-e video card will want more than 350 watts (for the low end cards). Getting a new computer might be worthwile.
I hope this helps.
Posted on Apr 13, 2010
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
My son saved up and bought a Gateway SX2855-UB12P. We have upgraded to 8MB of RAM and now are looking to upgrade the video card which currently is a PCI Express x16 Graphics. Given his machine is a en
Hope you mean upgraded ram to 8 GB 8 mb is not much ram to run a computer.
To upgrade your computer's graphics card, unfortunately you can't just simply purchase a card and install it to your computer. Before purchasing a card, you must first confirm what is compatible with your motherboard. Graphics cards use either AGP or PCI Express technology. Many older computers use AGP. AGP cards can vary in version and bandwidth, whereas PCI Express cards can vary based on their lane . Moreover, the card itself is not your only consideration when looking to upgrade your computer's graphics. You must also consider the strength of your computer's power supply as well, since most newer cards use a lot of power. Download, install and run SiSoftware's Sandra (see link Below) to find out information on your motherboard. http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html Click the "Mainboard Information" icon, then write down the information next to "Manufacturer" and "Model." Navigate to the motherboard manufacturer's website. If you are not sure of the website's URL, enter the manufacturer's name into a search engine to find the company's website. Go to the support page and enter your motherboard's model. Download the motherboard's manual or review the specifications. Search the manual or specifications for "Expansion slot," "AGP" or "PCI Express." If the expansion slot uses AGP, note the version (AGP comes in 1.0, 2.0 and 3.0), as well as the bandwidth (1x, 2x, 4x or 8x). If the expansion slot uses PCI Express, note the amount of lanes (x1, x4, x8 or x16). Search the manual or specifications for "Power," "PSU" or "Power Supply." Write down the power supply's voltage (3.3V, 5V or 12V) and amp rating (designated by "A"). Not all manufacturers list the amp rating in their documentation, so you may need to contact the manufacturer for more assistance. Compare the graphics card you want to buy to the motherboard's expansion slot. AGP cards won't work in motherboards using PCI Express, and vice versa. Similarly, AGP 3.0 cards won't work in motherboards using AGP 1.0. A PCI Express x8 card will not fit in a PCI Express x1 slot. Check the voltage and amperage of the video card to the voltage and amperage on your motherboard. A video card that requires a higher amp rating requires a powerful PSU. Hope this helps.
b>
Dec 24, 2012 | Computers & Internet
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Good Luck
Jun 10, 2009 | Gateway GT4024 PC Desktop
Video card
You do not give a reason for wanting to add a video card to this laptop, whether the video is not working or you just want to upgrade. I just looked at Gateway's support site and it appears the video that is standard with your laptop and motherboard is an integral part of the motherboard and cannot be replaced or upgraded.
Nov 28, 2008 | Gateway MT6451 Notebook
Computers & Internet Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
