Question about Craftsman Portable Generator 4000 Watt Rpm 3600 Model : 580.327053
Generator stopped working
Keeps running if I continually push the prime bulb. Gas tank ran dry earlier.
  • Craftsman Master
  • 7,482 Answers
Hi miked2015
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Nov 01, 2012
I have an Onan 6.5NH-3CR generator in my motorhome. It will not start, but the fuel pump continues to cycle until the fuse is removed. Any suggestions?
You likely have a break/leak in the line between the fuel pump and the gas tank. It may likely be right adjacent to your fuel pump. This scenario causes an air leak and doesn't allow the fuel pump to retain it's prime so it cannot build up pressure to actuate the auto shutoff.
Jan 29, 2015 | Electrical Supplies
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | John Deere Garden
Lawn Trimmer will not run
Have you checked the fuel line inside the tank? Usually there is a little filter on the end of the line inside the gas tank that when it gets dirty with restrict the flow of gas. Go spend $3-4 and replace and that should fix it. If it doesn't then I am guessing you probably still have something on one of the jets on the carb.
Good Luck
Jul 02, 2013 | Garden
The primer bulb on my Troy-bilt TB20CS will press in but it doesn't feel like it's pulling in fuel. Earlier after filling the gas tank, I noticed a little gas was leaking, and saw that the tube...
Or it could be like mine. I turned it upside down to take the cover off (Troy Bilt) to clean the air filter. Put it back together and the primer won't fill. Also it looked like air was coming into the bulb from the carb. Weird, since it was filling just a minute ago. Turns out the fuel lines in the tank were dry rotted. When I emptied the fuel tank, bits and pieces of fuel line came out along with several washers and a weight that goes on the end of the hose. Looking inside I saw a hose not connected to anything. Pulled it out and it came out in pieces (kept breaking when I'd grab it). That's why it's not connected to anything! Also why it won't prime or start. Probably also why it was getting to where it didn't run very well, and only on the A choke setting. It would cost almost as much to fix as to buy a new one. Bummer. For $90 though, if lasted five years. Maybe if I change the lines earlier on the next one I can even get more life out of it.
Jul 09, 2011 | Troy Bilt 17 Inch 29 Cc Gas Powered...
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Ryobi weed eater 30cc
Drain all the gas/oil mix out of the system. Press the red prime bulb several times until there is no fluid in the line. Pull the spark plug and clean it with a soft dry rag. Reassemble and fill tank with 2 cyl/gas mix. Prime it, then pull several times on the start cord. That should work.
Aug 05, 2008 | Electrical Supplies
Craftsman Portable Generator 4000 Watt Rpm 3600 Model : 580.327053 Logo
94 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
