Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I think I messed up password on secure network. How can I reset modem/password
  • 61 Answers
There should be a small button behind the router, you should be able to only press the button with a pin or a pen, something small. Keep it pressed for 15 seconds, then try the default username and password.
Posted on Jan 04, 2009
So, I bought a NetGear Wireless Cable Modem/Router Combo CG814WG v2 from Amazon and received it today. I got it switched out with my comcast modem and am up and running no problem. Then I successfully got...
If you cannot access the router setup, the only way to get back to it is to press and the router reset button to place the router back in the factory mode. Then the "admin/password" default should once more work for you. Do not confuse the router userid/password with the wireless name/password. They are different. When you set up your wireless network, your SSID is the wireless network name. Then you should select WPA2 personal as the security encoding. Then select a password for the wireless network and enter it. Be careful as they are case sensitive. Use a long password for best security. Use a short phrase that is easy to remember, such as youwillneverguessthis. Then save it and try again. Routers can be frustrating til they are set up. Good luck!
Dec 24, 2014 | NetGear Computers & Internet
Tip
Wireless Network Reset and Setup - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Next
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_field_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
  • Click on Wireless Security
  • Find the Security Mode field
  • Choose WPA2 - Personal
  • WPA Algorithm choose AES
  • WPA Shared Key type in your new password you will use to connect to your network
Click Save Changes and your router will now reboot. You will now need to enter in that same password (WPA Shared Key) when you first connect with your laptop to your wireless network
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
How do I secure my wireless and add a password?
hi, I think you may try WPA2+AES setting while setting up wireless connectivity, it will ask network key to setup. It is more secure setting for wireless usage.
Sep 03, 2012 | D-Link (DCM-202) Modem
I installed or should I say messed up an installation of my Motorola WR850G wireless router connected to my cable modem. I did the 30 second reset and that did no good. I can't reach it via it's...
Try contacting your internet service provider. Your modem seems to be on walled garden status meaning the modem is not authenticating any device.
Aug 29, 2011 | Arris WR850G Router (DHWR850G)
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
How to find the network key in my modem
I'm assuming you are talking about a wireless router requiring a security access key. They are password protected. If you don't have the password your only option is to reset the modem (literally, press the reset button) and set up a new password. If you have the setup menu password you can log on to the modem and look at the wireless configuration menu. Some models allow you to actually view the password - there is a toggle setting that changes the password from **** to displaying the actual characters.
Sep 19, 2010 | Computers & Internet
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
Versalink model D90 327W15 06 Saying type and connection unkown for my wireless connections. I have messed with it trying to fix it. I don't know what I am doing, but it keeps changing the IP address. I...
don't worry pam, if all else fails, reset the modem. you can do that by pressing and then hold for 30 seconds the reset button at the back of your modem. by resetting your modem it will go back to its default settings. if you think you've messed up the configuration by trying to fix it. this is the best thing to do. by resetting the modem you will be able to start fresh.
you can access it again by typing 192.168.1.1 in the address bar, username is admin, password is password. it will ask you to type a new password, make it admin as well so you won't forget. after that you can begin again to reconfigure your modem. if you are unsure of what to do, i suggest you call tech support of your isp provider and they will be able to help you with this. if, however, you know that your connection type is DHCP or OPEN PPOE, you might not need to call tech support, it will automatiically find your network and then "plug and play" you will be able to go online. but if you're connection type is PPPOE, you will definitely have to call tech support to make sure you will configure it correctly, all you actually need is the correct username and password for your connection. it's usually the one you use for your email if your isp is verizon for example. just remember if all else fails, reset the modem. it won't reset if you press it quickly, you need to press and hold for a minimum of 15seconds;
Nov 16, 2008 | Gateway WESTELL INC. A99-327W11-00...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
