Question about Panasonic Toughbook CF-27 Notebook
The display is incorrect
I can get 800 by 600 resolution but only 16 colors. This is after image restoration. This is a CF27EB reconditioned by Duracom. P3 500mhz win98se. Any Ideas on what the adapter is supposed to be?
  • 144 Answers
Well from a quick google i can see the original manufacturer was Panasonic. As a general rule of thumb , if you cannot get higher than 16 colours and 800x600 resolution then thats probably all the graphics on the laptop can support. Looking at the specification , its obvious that the laptop is quite old and back when windows 98se was the mainly used OS and Pentium 3's under 1 ghz were common , 800x600 with 16 colours was probably the best available.
As windows update wont be any use to due no more support for win98 , right clicfk My Computer , go the properties and click the Device Manager tab. Under Display Adapters , you will see the adapter for your laptop. You can try right clicking it , clickuing update driver , letting it search and see if it finds one. This may solve your problem as sometimes driver updates allow for more resolutions.
Please post what device manager ssays under Display Adapters if you get stuck and il try and find an updated driver.
Posted on Jan 04, 2009
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I am missing fine details in computer graphics
Hi! I'm a computer-based graphic artist and also a photographer who does digital editing. THe difference between the display settings makes a big difference. Using 32 million colors rather than 16 million is significant for image quality. Also check your display's resolution settings.
How To:
Right-click on the desktop background.
Select "Properties".
Go to "Settings" to find Screen Resolution and Color Settings adjustments.
Clicking the "Advanced" button gives you more options.
One final idea:
Check to see if you are using the correct display adapter (driver), and that it is the most up to date one. A generic, incorrect, or obsolete driver can affect visial performance.
Hope that helps!
Steve
Jun 15, 2011 | Computers & Internet
When I press the OSD reset button to get the screen to optimize the display, the displayed image moves 3 inches to the right (so I get 3 inches of black screen on the left) and the display looks washed...
Hi Mdamon,
Please follow the below steps to solve your problem :-
Your LCD panel has the settings button which you need to use to adjust your LCD screen to the center and make sure there is no black strip remaining after appropriate settings,
To make things easy for you , click on the below to download the manual directly so that you have a complete idea of the steps that are supposed to be taken for the screen adjustment.
There are many factory settings of different settings that are preset and can be activated using the panel.
Tip :- Try changing the screen resolution via the display properties from your desktop as an incorrect resolution could result in bad images or blurred images.
http://bit.ly/lMjygS
Hope this helps, your feedback would be appreciated.
May 13, 2011 | Envision EN9410 19" Flat Panel LCD Monitor
Lost my 32-bit color resolution
if its a stock system with out upgrades can go to
HP select your OS then select graphics
Apr 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
May 23, 2008 | Computers & Internet
Display module incorrect for super vgastb nitro3d how do i reset this
you need to find the correct drivers for your video card.
Jan 05, 2008 | Microsoft Windows 98 for PC
Panasonic Toughbook CF-27 Notebook Logo
158 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
