Question about Frigidaire FGF326AS Gas Kitchen Range
Electrical fire in stove
I noticed the speed cook was not going on. the oven worked anyway.i shut the oven off and went up stairs.with in 5 minutes the stove was smoking. i then pulled the stove out and shut off the gas and pulled the plug.help''''''''''
  • Frigidaire Master
  • 3,087 Answers
I would call the gas company and have it checked out in case you had a gas leak on the stove which may have brunt the wires , it safe with the gas and elec off,
Posted on Jan 04, 2009
Amana Eletric Range, not working
check to see unisulated wires......but dont forget to turn the breakers off.by the way use electrical tape to insulate open wires.
Feb 05, 2014 | Amana AER5844VAB Electric Range
Baking
I sounds like an issue with the pilot light. Our stove does the same. Sorry that's not much help
Jul 23, 2012 | Jenn-Air JES9750 Electric Kitchen Range
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
While cooking a turkey the oven reached the heat setting and the turkey was placed in to cook two hours. After two hours when the turkey was removed the heat was off and the turkey had not cooked. ...
next time send the model number so i csn look up your machine,open the bottom draw and on the frame you'll see a tag with the model and serial numbers,all i would need is the model,anyway you must have a computer board in the clock assy. and sometimes just like your house computer has to be restarted because for some reason the computer froze and shutting down the power will reset it,if this keeps happening you'll have to change out the clock assy.but i've seen this happen,the first thing i do when i go in on a job and the machine has a computer board in it is to unplug it for 5 minutes to see if it resets and usually it doesn't happen again unless the power went out or something like that,keep an eye on it you should be fine but if it happens again soon for no reason like i say you might have to change out the clock assy.good luck any more problems i'd be happy to help.
Apr 10, 2011 | Whirlpool Electric Range
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Top of stove hot when oven on
I suspect this may have been happening for quite some time and you may never have noticed it. MANY ovens vent near one of the stove eyes. If you lift the cooktop for 'servicing', I bet you see the little vent. It is usually in the back right underneath the cooking surface. Check to make sure it is not blocked, clogged or has rusted out/off.
Mar 04, 2009 | Magic Chef 9815 Electric Single Oven
I have 2 problems. The first is that the oven, every minute and 10 seconds or so, has to reignite itself. This goes on constantly for the duration of the cook time. Now a new problem has just occured. The...
The first problem - I am not sure this is a problem - it is normal for ovens during cooking to cycling on or off several times. Is this something you notice recently or this is the first time you have ever noticed this.
The second - this may be happenning because the microswitch at the knob may be deffective (constantly on) check this and the wiring harness to make sure nothing is shorting out
Regards
Oct 01, 2008 | Viking Kitchen Ranges
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Frigidaire FGF326AS Gas Kitchen Range Logo
151 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
