Question about Toshiba 50HX81 50" Rear Projection Television
CONVERGENCE? I have the dreaded convergence problem. I noticed that the blue line is curved at the bottom and seems to be lower on the left side of the screen. When trying to use the manual adjustment I have noticed that the Red can be moved up,down, left and right. When trying to adjust the blue I can make it move left and right but will not move up and down. I just replaced both of the STK392-110 IC's last night. The condition is exactly the same as before. I did not seen any burnt resistors,cracks or other hot spots. This TV is 6yrs old and has been working great until this. Could there be a problem with the CRT? Is there a good way of checking them to confirm? Any and all help is very much appreciated
  • GLENN HOUSER May 21, 2007
    Thank you for your help.
    I did find a burnt resistor. I replaced that resitor and now instead of the left (facing the front of the TV) end of my blue line curving downward it is curving upward and seems to be somewhat squiggly at the end. The blue line can be moved in all directions now and have tried the 9 point convergence adjustment and still cannot get rid of the curved blue line.
    I have checked the rest of the resistors on the convergence circuit board and all seem to be in the proper range.
    I even tried to move the rings on the Blue Gun.....still have the curve....
    Is it possible tha a messed up one of the IC's when powered up with the open resistor? How would one determine that?
    Since the Green, Red, and Blue connectors are the same, would it be possible to swap the connectors at the circuit board to isolate a possible bad Gun???
    Would any of these tests or questions be covered in the Service Manual?
    Thanks again for any and all help.
    Scholar:
  • 77 Answers
You can not tell anything about those resistors by sight get an ohm meter and test them. Disconnect the three plugs going up to the Yokes first though or you will not get an accurate reading. Check the resistors around the blue yoke plug closely this is where you will find your problem.
Posted on May 17, 2007
  • josh vannoy May 22, 2007
    well if the blue can move in all directions then you are probably fixed. does the blue move in both directions at all nine points? but you can not get close enough? If this is the case you may need to do the alignment in the service menu. The possibility of damaging those IC's is remote but I will never say impossible in this line of work. Swapping the yoke plugs will isolate the yokes but your problem is not the tubes and i really doubt the yoke, that is VERY uncommon. Major adjustment in the service menu is not that uncommon after an amp job. I would move the rings back they really shouldn't be moved, they are basically used for centering so use the center cross in the customer convergence menu to adjust them back. To enter the service menu, mute the TV (push it twice if it has the half mute feature) and then press and hold the mute button again on the remote, while you are holding it press the menu button on the TV. You will see a small "s" appear in the right corner of the screen. now press the menu button on the remote and the "s" will dissappear on the right and you will see an adjustment on the left, probably "rcut". Now press the number 7 (NOT ANYTHING ELSE!!). You should now see a large cross hatch covering the screen with a curser somewhere. The number 5 will freeze the curser for adjustment or start it flashing to move it to the next spot. While it is solid you can press the number 3 to change colors. and press 8,4,6,2 to adjust the selected color. While it is flashing 8,4,6,2 will move the curser around the screen. Only adjust the blue and notice that areas around the spot you are adjusting are also being effected. It takes a little patience and a lot of getting used to as you can adjust one spot and bring another out so you have to correct it and then go back to the original spot and over and over again. do yourself a favor and beginm with small changes. Good luck and let me know how its coming.
The blue lines on the left lower side of the tv will not converge. The tv has never given me a problem. I woke up one morning and powered it on and noticed the blue is misaligned. I tried converging and...
This problems can happen to the DLP tv any times of it tv life.Tv is 100% have a convergence problems.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Nov 13, 2009 | Philips 60PP9202 60" Rear Projection...
Screen has curves
Bad convergence IC's and possibly yoke return resistors located right by the convergence IC's
Craig
May 08, 2009 | Televison & Video
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Blue Convergence Problem
This is a pain and you have to be carful in doing this fix. Its basically the bulb thats shot, its got that liquid in it so DO NOT BUST IT OR YOU WILL SCREW THE BOARD UP! THen you have to get a new TV
Oct 26, 2007 | Philips 46PP9302 46" Rear Projection...
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
