Question about HP Laserjet P2055 Printer Laserjet 1200 X 1200 Dpi Laser 50000 Page
Hewlett_paokard error:B0601 - HP Laserjet P2055 Printer Laserjet 1200 X 1200 Dpi Laser 50000 Page
2 Suggested Answers
heavendgamin
  • 3 Answers
SOURCE: HP LASERJET MFP 1005 HAVE SHOWS ON DISPLAY ERROR B0601
head to this site there are instructions on how to fix it
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01687323-5
Posted on Oct 27, 2015
Tip
What is a Scanner Error 5 Hewlett Packard M2727nf MFP
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M2727
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
This printer is under HP Warranty until Mar 23, 2011
Contact Hewlett Packard for Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
2 parts need to be replaced at the same time
Parts Required as follows
Formatter - CC370-60001
Scanner/Flatbed - CB532-67905
Warranty Extension Expiration 2011-03-23
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
Hewlett Packard Laserjet M1522
Contact Hewlett Packard for possible Warranty repair. See Link Below
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
Packard erroe :b0605 Hp 2055dn show message when booting.how to solve
The printer's firmware (controlling software) has mulfunctioned.
A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. If you are handy with a computer, the first step is to follow HP's trouble-shooting steps and re-flash the firmware in BootCode mode, then reboot the printer. Re-flashing the firmware doesn't always help, but it's a good first step. See HP's trouble-shooting document here: Error
B0601, B0602, B0603, B0604, or B0605 displayed during printer initialization
Check this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01687323&lang=en&cc=us&contentType=SupportFAQ&prodSeriesId=3662052&prodTypeId=18972&printver=true
If this process does NOT fix your B0605 firmware error, you will probably need to replace the formatter assembly, which is the main logic board in the printer.
Dec 27, 2015 | HP Office Equipment & Supplies
Oct 27, 2015 | HP Office Equipment & Supplies
The printer is displaying error: B0605 on the screen
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Sep 21, 2011 | Computers & Internet
Printhead Error
CN642A - Printhead Unit
This product is compatible with :
Hewlett-Packard OfficeJet 6000
Hewlett-Packard PhotoSmart B8550
Hewlett-Packard PhotoSmart B8553
Hewlett-Packard PhotoSmart C5380
Hewlett-Packard PhotoSmart C6380
Hewlett-Packard PhotoSmart D5460
Hewlett-Packard PhotoSmart Premium Fax
Hewlett-Packard PhotoSmart Premium Fax C309 Series
Mar 19, 2010 | HP Office Equipment & Supplies
Error no b0601
There are two causes for this error, its either going to be a problem with the firmware, or the driver for the printer.
Go to this page for a further explanation and the steps to take on how to resolve the issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3662052&prodTypeId=18972&objectID=c01687323
Feb 09, 2010 | HP Office Equipment & Supplies
HP Laserjet P2055 Printer Laserjet 1200 X 1200 Dpi Laser 50000 Page Logo
130 people viewed this question
Ben Johnson
