Question about Bosch Axxis WFL 2060 Front Load Washer
How to change the shock absorbers in a bosch washer
I need to replace these parts and the drawing that came with the new part shows drilling one side of the shock holder, knocking out the existing pin and replacing it with the new metal pin in the kit. The pictyre looks like I should use a 13.5mm drill bit and drill to a depth of 30 mm . Is this correct? The instructions only show pictures, there is no words.
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
  • 1388 Answers
SOURCE: BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Posted on Dec 16, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Posted on Feb 11, 2009
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
Show me how to replace marker or side light
Hi and thank you very much for your question.
You need to remove the headlamp assembly in order to replace the side light bulb, but it's not too difficult. First, remove the grill which is held in place with two clips. Once the grill is out of the way, you need to locate two pins which pull upwards out of the headlamp. You should be able to pull the pins with a pair of pliers, but you may need a lever to start them moving. Once the pins are out, the lamp will pull forward far enough to get to the side light bulb holder. The bulb holder twists out and the bulb just pulls out of the holder.
I hope this answers your question?
Jul 16, 2017 | Cars & Trucks
Hr 3000
Frequently the problem for this is a plastic ring that has three pins in it. Normally the pins break through the bottom of the ring.
You need to take covers off. Strip SDS chuck. Remove plastic cap from end of drill then remove large internal retaining ring. Tap end of drill with mallet and eventually the tool holder will come out.
At the bottom of the tool holder there is a thin O ring (all this does is keeps a plastic gear and springs on the tool holder.) Remove this ring gear and springs can now be removed. You should now see the plastic ring (approx. 30mm long) Examine ring and pins, probably need to replace ring. This is usually the cause of not hammering, I have found changing seals works for weak hammering. Although having stripped the drill to this point I normally change the O rings on the hammer and piston. Rebuild is reverse of stripping be careful with the thin O ring not to snap it.
Mar 15, 2014 | Makita Drills
How to remove bit from the 5351
the parts are obsolete to replace in the most case if it will come out the driving guidance is often worn in the bit holder and a
lockup will repeat soon
Sep 09, 2012 | Milwaukee Drills
Do I need to replace the front axle damper after installing new starter in my 2001 sport trac?
Hi Pete, If the bolt you refer to is part of the shock absorber you will need to replace the damaged unit. If you replace one we recommend replacing both on the same axle. If however the unit is a McPherson strut type suspension, and the bolt you refer to is that which is mounted onto the shock pad, bolting onto the shock tower it can be replaced with another. It is a special bolt which has a splined shoulder. (The spline is to lock the bolt in place while being tightened) To replace it. knock out the broken piece with a pin punch and insert the replacement. If you need to remove the shock pad from the assembly, you will need to use suspension spring compressor clamps. Hope this info is of help? Regards John
Sep 09, 2012 | 2001 Ford Explorer Sport Trac
Acura Legend 1991. trying trying to fix front turn signal..
buy a new one ,or solder 2 wires to the bulb and then join this to the two existing wires of the loom,drill a hole in the bottom of the bulb holder so the wires can run through it so you use the old bulb holder to hold the bulb in place in the light
Nov 15, 2009 | 1991 Acura Legend
Shiftshaft on 1996 Royal Star - Updated?
When you say "pin holder", I'm assuming that you mean the part that Yamaha refers to as the segment - it holds 5 short and one long dowel pin at the end of the shift cam assembly. In 1996 the segment part number was 26H-18185-00-00, it held five 93604-17198 dowel pins, one 93604-21197-00 dowel pin and a 26H-18561-01-00 side plate. However, in 1998 the segment part number 4NK-18185-00-00 held five 93604-12037-00 dowel pins and one 93604-16092-00 dowel pin; the side plate had been eliminated. The shift shaft for the early combination was 4NK-18101-00-00, for the later combination 4NK-18101-01-00. If you recognize the "pin holder" part number, you will know which shift shaft you should be using.
Jul 16, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
Wont final spin , had loud knock but quit
You have a broken shock absorber and you need to relpace it. Remove the lower inspection panel by unscrewing the 2 screw at the bottom of the panel below the door. Remove the panel and look inside on either side of the wash tub. You will see the 2 shock absorbers and one or both will be broken. There are 2 plastic pins holding them in place. On the pointed end of the plastic pin, there is a tab that needs to be depressed (use a flat screwdriver) so that when you pull on the other side with a plier, the pin will come out. Go buy the replacement shock absorbers at your local appliance shop. To install, put the absorber in place and push in the plastic pins. Make sure the correct end is up. Replace the front panel and the job is done.
May 23, 2009 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
Broken latch on xtremevision car dvd receiver. XV-4.0. the part that holds the faceplate that tilts out. i can not find any place to get fixed.
OK. very careful take a small drill bit, drill one hole on each side of the face holder the part the shows when the stereo is mounted drill juts enough to insert a pin or find a nail about half inch with the head so you can put it in when you close the latch (note.) the latch is hollow so you can drill about one 1/8 be very careful when you drill tape the tip of the drill bit so you don't drill more than what you need. It works I have my for a year good luck. motoroil
Apr 27, 2009 | Xtreme Sound Car Audio & Video
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Nov 02, 2008 | Bissell 6590 CleanView Bagless Upright...
Bosch Axxis WFL 2060 Front Load Washer Logo
1,315 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
