Question about Dryers
Li am trying to hook up a light switch from a wall plug but i need help i would like if you could help me thank you
  • 5,245 Answers
11-1-12
Yes, here is illustration.
Copy following link that shows drawing power from another outlet with Black Hot and White Neutral. Only the Black Hot wire connects to new switch.
http://waterheatertimer.org/How-to-wire-switches.html#add
Posted on Nov 01, 2012
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
I want to use a TM8111 swithch to control 3 devices. A ceiling fan/light combo, night light and a vanity light. How do I hook it up?
Following image has basic wiring plan.
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Each Load (light-or-fan) has to have separate wire running to switch box.
If night light is plugged into wall outlet, then a new wire will have to be added going to switch box.
Most night lights have built in photo eye, and on-off switch.
Add a comment for more help and include specific wiring and what you have tried so far.
Jun 14, 2011 | Pass & Seymour Legrand TM8111 Three Single...
Can a normal two part wall switch run all three parts of a panasonic whisperlite fan/light/night light combo
Was it wired up there before with the 2 switches? One for the fan and the other for the light? You will have to take the plug out of the fan and cut the ends and wire nut them to their wire on the switch. Otherwise it be on when the switch is on. Or,,,, Find the right wire inside there and make sure it is separated from the light and hook it up that way, then it can stay plugged into the fan unit. Check it out, hope this helps.
Oct 16, 2010 | Panasonic WhisperLite Bathroom Fan with...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Does the red wire coming out of the ceiling go to the blue wire in the fan. i cant get the lite kit to come on
The white wire in your ceiling box is USUALLY the neutral wire. Green or bare wires are ground wires. Any other colored wires are generally hot, switched or unswitched. If changing the position of a wall switch makes a white wire hot, it is NOT a neutral wire. You need a test light, generally an inexpensive neon test light available at any hardware store, and a book on basic wiring would help. To control the fan and light separately, assuming you have not installed a wireless control, you need two switches, one for the fan and one for the light. If you do not have these, you need a wireless control unless you have a spare wire in the wall switch box or you need to be satisfied with controlling the separate functions with the pull chains. Check the ceiling box wires. Put one lead on the ground wire or, if you have steel boxes, on the box. Remove the wire nuts on the other wires, being careful not to touch any wires or touch any of the wires to each other or the side of a metal box. Touch the other lead to the other wires, one by one. If the light comes on, the wire is hot. Try the wall switch(es) on and off and see what changes. To make the fan or light work it has to be hooked up to a neutral wire (white, never hot regardless of any switch positions) and a hot wire. The same is true for the light kit. If you do not have or want two wall switches, one for the light and one for the fan, you need to identify the wire that is hot when you turn on the wall switch and hook it up to the black (fan) wire AND the blue (light)wire. You then control both with the single wall switch in conjunction with the pull chains. If you have two switches in the same wall box, and they make two different wires hot in the ceiling box, hook one to the black fan wire and one to the blue light wire. If you're set up with only one switch, and you're lucky, you may have an extra wire in the same cable from the ceiling box to the wall box, with a wire nut on each end. In that case, install a second switch for the light (or a combination switch designed to control both a fan and light). Hook the hot wire from the wall box to both switches (or the hot terminal on the combination switch) and the other two wires to the other two terminals that go to the ceiling box to feed the light and fan. Never use a light dimmer switch to control a fan or a fan speed switch to control a light. If two or more switches in different areas controlled the original fixture in the ceiling box, things can be complicated. If the same wall switch makes two different wires hot depending on it's position, for example, it's a three or four way switch. The above description also assumes the wall box is fed from the ceiling box, but the opposite may be true. There may also be wires in either box that are feeding other circuits in the house. Electricity can kill or burn down your house. If unsure of what you are doing, hire a licensed electrician. Also be aware that if you touch the leads of the test light to two wires that are both hot, the light may not come on. Always test with one lead on a ground or a wire that you are sure is a neutral wire. I recommend tuning off the power to all the circuits in the boxes that you are working on, after you have determined what the wires are, by shutting off the circuit breaker(s) or removing the fuse(s). There may be more than one circuit in a box.
Feb 12, 2010 | Hampton Bay 24002 Ceiling Fan
Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Jan 31, 2010 | Minka F719-TSP Treville Tuscan Patina...
I have a GE in-wall digital timer that I want to use to replace a light switch The light swithc has 2 wires, the timer has 3 which does not make sense. What do I do
Now you need to know a few things before you trying this, #1 Where the Circuit breaker for the lighting you are working on is located. #2 which wire is your power/hot wire going in to your switch. #3 which wire is going directly to the light. #4 what a neutral/return wire is. #5 some general electronic terms.
If you do not understand or if you cannot understand the above paragraph Please seek the help of a qualified/licensed election.
Well the reason the wall timer has 4 wires, is that it IS NOT just a Switch. It is in fact an election device. It requires Power (your Black Wire), a Return (your White wire), and a Ground (your Green wire). It also has a Output (your Red wire), this output wire controls your light (turns it on or off).
IF you’re still with me?
#1 turn OFF the Circuit breaker for the lighting you are working
#2 Take a part the light switch box for the light you are working on (only disassemble as far as necessary)
#3 Take your Ground wire and hook it up to the ground within the same location.
#4 Take your Return wire and hook-it-up to the nearest return wire within the same location.
#5 Take the black wire on the wall timer and hook-it-up to the Hot/Power wire.
#6 Take your Output wire and hook-it-up to the wire going directly to the light.
#7 Inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#8 Before placing everything back tougher turn ON the Circuit breaker for the lighting you are working then run a test.
#9 OFF the Circuit breaker, then inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#10 If everything is working then place everything back tougher. Then turn ON the Circuit breaker.
#11 If you did not have your Circuit breaker pop/turn off the lighting you were working, your dun.
Dec 18, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Will not power up, need replacement wall plug
Radio Shack can hook you up. Take your old transformer to them and they will help you out.
Jul 09, 2008 | Wave Industries OLY-OL3000 Globe Phone
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
18 people viewed this question
Top Dryers Experts
