Question about Cosco Alpha Omega Elite - Hammer Print
Shoulder straps will not extend
I can not get the car seats shoulder straps and lap strap to extend to fit around my toddler..how do i lenghthen them so they fit around her she is skinny for her age so I do not understand why they do not fit her. Do you have to buy new straps for it?
In between were her legs are there is a cocso sign push down on the button and pull the strap tight. A black strap should be handing out from under the button.
Posted on Jan 04, 2009
  • frankiejoe Jan 04, 2009
    No you do not have to buy anything new just pull on the strap under the cosco and you can tighten the strap.
Can you use a lap belt only with this booster seat?
  • Yes you can. The belt goes between the front and rear sets of arms on the booster seat. It is always advised to use a shoulder strap with it but you need a clip to bring the direction of the top of the shoulder strap [seat belt] to avoid neck (throat) impact. If this is not possible at the moment then run the shoulder strap behind the child and the lap belt portion over their lap, between the two sets of arms, as they sit in the seat. Then get a seat belt locking clip soon. You can get them anywhere on the net and at your local department stores as well for $7 or so. Like this one here. http://cheapboostercarseatcheapprice.tk/cheappriceoffer/graco-seatbelt-locking-clip-B0002ADQOU
Regards, Tony
Jun 10, 2011 | Cosco Auto 22-297
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
I am trying to refit the straps on a britax car seat (For children 9-18kg) but I cannot get the straps attached to shoulder pads positioned so they are on top of the shoulder straps when coming through the...
hi here is a manual for the eclipse version i have a first class and mine fit the same way so assume they all fit like this, if this doesnt work i will try to help further I know how to do it but cant explain in words
click here anyway worth a try
http://www.britax.co.uk/media/142518/11.pdf
Feb 07, 2011 | Baby Gear
Can a baby-start remi car seat be fitted in the car with a lap strap
Stores had recalled a Remi 2 Travel Basic Car Seat as a precautionary measure.There is a risk that the car seat may not provide the required restraint if the seat straps can be removed and then rethreaded. However this seat should strap in with the lap strap.
Aug 10, 2010 | Baby Gear
I have a Cosco Juvenile car seat and my husbands car. In the back seat he has seat belts that are a combination shoulder and lap strap. How do you connect the car seat so that it is secure in the back...
you take the seat belt and put the lap strap thru the back of the carseat and click in in on the oher side pull tight and carseat is secure. the shoulder strap part doesnt effect the safety of the car seat at all
Sep 12, 2009 | Baby Gear
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Car seat straps
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
Oct 02, 2008 | Graco ComfortSport 8431
Evenflo Discovery 5- Pink and green
you need to take the seat to the dealer for safty reasons
Mar 31, 2008 | Evenflo Discovery - Midland Blue
Car seat trouble
Where is the button to release the shoulder straps for a comfortable fit or model # 8465HGA
Dec 03, 2007 | Graco SnugRide - Giselle Infant Car Seat
Cosco Alpha Omega Elite - Hammer Print Logo
299 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
