Free download of Tascam DP-02 dvd tutorial - Audio Players & Recorders
  • 189 Answers
SOURCE: what kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Posted on Jul 24, 2008
SOURCE: Tascam DP-02
I had the same message on my DP02 error 12 please power down. I went to an electronics store and asked a computer technician and he said it probably isn't getting proper power to start up .We looked at the manual specifications for power and found it needed a power adaptor which has an output of 12 volts and 2.5 amps which is 2500ma. Once I put that adaptor on it everything powered up and it works great.Look for an adaptor that says output 12v 2500ma and it should work fine.
Posted on Jan 03, 2009
  • 189 Answers
SOURCE: TASCAM DP-02 (You don't even include it here in your products!)
Here's a link to the DVD tutorial for the DP-02:
http://www.amazon.com/Tascam-DP-02-Video-Tutorial-Manual/dp/B001JP6572
There is also a video on Tascam's support page for this product that you can download for free:
http://www.tascam.com/products/dp-02;9,16,3580,19.html
You can ask questions here or consider joining Tascam Forums (I think it costs $4) and talk to Tascam experts from all over.
http://www.tascamforums.com/
The DP-02 operates almost exactly as the DP-01 did, so manuals and videos for one should pretty much guide you correctly when applied to the other, but the video in the first link is the correct on for the DP-02.
Hope this helps.
Best of luck.
bd.
Posted on May 29, 2009
SOURCE: I need a driver for a Tascam DP-01FX
ok first i just wanna prepare ya on how bad your gonna kick yourself on this one, i have a used one and dont really use honestly i hate it...but i decided to mess around with it and decide to get sumthing decent and bring it to the comp for the first time...and i seen i had the same issue.. and saw that alot of people did to and they went on and on with no solution...so i gave myself 5mins to think and remember....and here ya go you ready... after you save all your songs correctly to get them ready for export...step 1.plug it into your usb port...step 2. ignore the fact that its not being noticed by windows...step 3. go to menu on ur tascam scroll down to disk hit yes/enter.step 4..now ur in the disk menu and right there the third choice..usb open/close hit enter and there ya go you will be prompt to open the usb port and everything is done your ready to go...when ur done u close the port...basicly an on and off switch for the usb port...i hope it helps and its not too late...good luck..oh it should be in the manual under usb...thats how i remembered it cause i remember reading it.
Posted on Jul 21, 2009
thydzik
  • 86 Answers
SOURCE: Tascam DP-02 is not power up.
you can buy a replacement power supply from here
http://www.audio-depot.com/index.php?main_page=product_info&products_id=2427
Posted on Sep 15, 2009
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Where can I find a free download for the usb driver required from the TASCAM DP-02 to my Windows 7?
Good day. I have come across the manual, and it mentions nothing about a driver required for Windows 7. Please check the manual and let me know. Kind regards.http://tascam.com/content/downloads/products/241/E_DP-02&02CF_web.pdf
May 25, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How to with tascam dp-02 dp-02cf
You can use headphones or monitor speakers that are hooked to an amp. If you don't have one ,consider downloading a manual:http://www.tascam.com/i-3582-232-128-1-4A000F90.pdf Pay attention to the caution on page 9 and the hookup diagrams are on pages 12 and 13. Hope this helps.
Jan 25, 2010 | Tascam Music
Anybody can help me with operation of Tascam 2488 neo. I find the manual trips me up and a simple manual would be great if available
Here's a 2488 DVD tutorial. You may even find it elsewhere at a better price. It is of great help.
http://www.amazon.com/Tascam-2488-Video-Training-Tutorial/dp/B000FTJ5UC/ref=sr_1_1?ie=UTF8&s=dvd&qid=1284348097&sr=8-1
Dec 26, 2009 | Tascam 2488 Portastudio Multitrack...
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Hope this helps.
Best of luck.
bd.
May 08, 2009 | Tascam DP01 All-In-One Recording Package...
Peavey PV14 to Tascam DP-02
The usual setup would be to use the main outs to your Tascam as the master faders control the levels there. The control room outs are more geared towards monitoring and are tied to the headphone outs level control.
Apr 20, 2009 | Tascam 2488 Portastudio Multitrack...
Just checking
you can get a mountain of support for it here
But they don't make mention of a DVD still available on the Tascam site. Perhaps you can go to Tascam direct to see if there is actually anything still available. There is always the youtube option to veiw it.
regards
Graeme
Mar 21, 2008 | Tascam 2488 Portastudio Multitrack...
78 people viewed this question
 Grubhead
Grubhead
