Question about GE JVM1410 Microwave Oven
No heating jvm1440bd
This GE JVM1440BD microwave has the only problem it doesnt warm. All other features work properly, even when you start it the light and the fan come on, and the glass plate starts rotating, but it doesnt get hot at all. I suspect the problem is the magnetron because the microswitches, fuse, and termistors are ok. i would like to know what test could i take to be completly sure and where can i get a replacement for the magnetron in LA area.
  • GE Master
  • 9,156 Answers
Before you take it apart, yours may be a model covered by a campaign under which GE is replacing "underperfroming" magnetrons and also putting in new stirrers and high voltage diodes. See this bulletin to see if yours is one of them: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If it's not covered, then we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk While you can't be completely sure without experience, there is a technical sheet in an envelope inside the oven which shows how to test the magnetron with an ohmmeter. Essentially there should be near zero between the two terminals, and infinity from either terminal to the case. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you'd rather find parts locally (at sky-high prices) check your Yellow Pages for Applaince Parts. *grin*
Posted on May 17, 2007
I have the replacement door handle for JVM1440BD. How do I get the door off?
bit tricky as you have to dismantle the door first then remove black back pannel to acces screw to the handle.best of luck be carefull not to pry open the pannel by using too much force
Mar 25, 2014 | GE Microwave Ovens
GE Microwave model JVM1440BD operates but does not heat
On most occasions, it is magnetron. If you on your oven and hear an humming noise, that usually confirms magnetron problem.
You could see how to test magnetron
http://www.gallawa.com/microtech/mag_test.html
Let me know, once you test this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | GE JVM1410 Microwave Oven
GE Spacemaker Micro
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
srtat
Jun 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2009 | GE JVM1441 Microwave Oven
GE Spacemaker Microwave Oven Model JVM1440BD: turntable doesn't work. When we press start, turntable make semi-loud noise while oven is cooking, but it does not turn. We can stop noise by pressing...
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE jvm1440bd smells like electrical burn
No, you are ok. The fuse can blow some time.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 11, 2008 | GE JVM1440 Microwave Oven
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
Jvm1440bd Microwave
I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
Jan 08, 2007 | GE JVM1410 Microwave Oven
GE JVM1410 Microwave Oven Logo
301 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
