Question about Electrical Supplies
RYi2000 GENERATOR WILL NOT START
CHANGED SPARK PLUG AND OIL. PLUG HAS SPARK BUT ENGINE WILL NOT TURN OVER
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 7 Answers
SOURCE: 2 year old honda eu1000i generator with new spark
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Posted on Sep 10, 2009
protek480
  • 1714 Answers
SOURCE: my champion 3500w generator stops all of a sudden
How long does it run? The 'oil pressure' switch will cause that....??
Posted on Sep 11, 2009
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Homelite hgn 0960a generator wont start no spark
Change Spark Plug. Check The starting Switch with a Multitester if it have continuity.Start it again and check Spark with the spak plug unplugged and with the crankcase check the spark.
Check the oil level. almost all the new and modern generators have included an oil alert gadget that cut off for saving the engine.check oil level and refill if it need.start it again.
Sep 02, 2014 | Electrical Supplies
I have fire and gas but will not start oil alert light on when crank
By fire I assume you mean spark at the plug. When turning the engine over with the key and the oil alert light comes on the spark is interrupted by grounding the system thus the engine cannot start.
First, look at the obvious things, check oil level if it is at the recommended level smell the dipstick if it has a strong smell of gas
change the oil and try to start it again. Be sure the plug is not soaked with raw fuel before you try the restart. I the problem persists you can disconnect the wire from the top of the low oil sensor.Try to start the gen. if it starts change the low oil sensor.
I hope this all makes sense to you , good luck with it.
BR
Jul 24, 2014 | Honda 3000 Watt Portable Generator
Allpower American. 10000w generator won't start? Changed spark plug, gas is flowing. What else can we try?
Make sure it has plenty of oil. Some engines have a low oil shut off. Pull the spark plug wire off and stick a screw driver down inside the spark plug boot and hold the screw driver about a 1/4 inch away from the top of the spark plug and turn the engine over to see if you have a good bluish spark. If you don't then you have a bad coil or rust build up on the flywheel. If you have spark make sure your gas tank is full with new gas. Make sure the air filter is clean. If that doesn't work try taking the bowl off of the bottom of the carburetor and verify gas flows through the float valve. If that doesn't work then you will probably have to remove the carburetor and clean it out.
Feb 15, 2014 | All-Power America All Power 10000w Apg3090...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
Not used for 2 years. It will not start.
Engine will
not start
1. Low on fuel or oil. 1. Add fuel or oil.
2. Ignition switch in "Off"position. 2. Turn to "ON" position
3. Faulty spark plug. 3. Replace spark plug.
4. Choke in wrong position. 4. Adjust choke accordingly.
5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
6. Unit loaded during start-up. 6. Remove load from unit.
7. Spark plug wire loose. 7. Attach wire to spark plug.
Apr 23, 2011 | Porter Cable 5,500 Watt Portable Generator...
WILL NOT TURN OVER OIL FILL A PULL START
Sounds like you may have oil in the cylinder. This is caused by engine tipping over or maybe the generator fell over on its side, etc. This ends up making it really hard to pull start the engine.
Anyway, try removing the spark plug (make sure the ignition wire is pulled out of the way) and then turn over the engine a few times (5 or 6 times) to get any oil out.
Then replace the spark plug and try again to see if it starts.
Mar 15, 2011 | Coleman Powermate Powermate 5000W...
Won't start. changed gas. oil is okay. added fuel additive. new spark plug.
Loosen bolt on float bowl. Fuel should start leaking from around top rim of bowl, if it doesn't then there is a restriction somewhere in fuel line or float valve is blocked in bowl.
Feb 21, 2011 | Coleman Powermate Premium Plus 6250W...
May 08, 2009 | Electrical Supplies
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
1,592 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
