Question about Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer
F101 Error Toshiba estudio2040c
What does F101 Error code mean and how can we fix it? We had error code F510 a couple of weeks ago and the service repair person replaced the entire hard drive.
    Habit-Forming:
  • 47 Answers
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Posted on Apr 29, 2017
  • 3 Answers
SOURCE: Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Posted on Feb 01, 2008
  • 990 Answers
SOURCE: I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Posted on Jan 10, 2009
  • 628 Answers
SOURCE: toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
  • 628 Answers
SOURCE: toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Posted on Aug 11, 2009
  • 30 Answers
SOURCE: Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Posted on Aug 14, 2010
Toshiba e studio 2051c showing F101 call for service 5 ERROR . How to fix it?
DH, Toshiba e studio 2051c showing F101, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Toshiba 256se 101 4 error
Toshiba studio 2051c Troubleshooting Manual
Aug 03, 2016 | Toshiba e-Studio 2051C Multifunction Color...
My Toshiba e studio 2051c showing F101 & call for service error . How to fix it ?
DH, Check/ read through the attached links,instruction and guides, Good luck
Toshiba copiere206l series error code F101 sub code 5
Jul 09, 2015 | Toshiba Office Equipment & Supplies
Error f510 in toshiba 306 mfd
Application start error
reinstall the HDD software
Jun 11, 2014 | Toshiba Office Equipment & Supplies
TOSHIBA STUDIO F101
hard disk problem, remove it, then attached it firmly, then start the mechine, 2/ 08, start, 690, enter, reeboot the machine appear, and reboot the machine
May 19, 2014 | Toshiba e-Studio 350 Copier
Toshiba e studio 256 se error cod F510
Application start error.
May 12, 2014 | Toshiba e-Studio163 Copier
How do i fix error code f100 1 for toshiba e studio 2040c?
F101 HDD failure,,08-9030..or update the firmware version.if not okey replace the HDD.
Jun 23, 2012 | Toshiba E-Studio 2040c Copier
Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer Logo
5,997 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
