Question about White Sewing 2999 Mechanical Sewing Machine
White sewing machine model 2999
I need to know how old this machine is and how much a buttonhole foot costs.( and if I can get the back piece of the machine and how much )
  • 231 Answers
Winter 2002 was when it was first released. Retail of $499.00.
Contact White Sewing Directly for parts =>
http://www.whitesewing.com/customer.asp
Posted on Jan 04, 2009
Can i use a walking foot to make a buttonhole on my 320 alna sewing machine
I don't see any reason to use a walking foot for sewing a buttonhole. The purpose of a walking foot is to move the top and bottom fabrics together. Feed dogs sometimes tend to move the lower fabric faster than the top fabric--a walking foot helps prevent that.
If you don't have a buttonhole foot for your machine, you can still stitch a buttonhole using a different presser foot.
How to sew buttonhole with an old machine
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
Sewing Buttonholes Without Buttonhole Foot
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Feb 28, 2018 | Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
How to Sew Button hole tutorial
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
How do I make a button hole
Put on your buttonhole foot. Slide the foot plate back and set the button in the back...this is how the machine knows how big a buttonhole to make. Pull down the buttonhole lever, gray plastic, which is to the left of the needle. Now use the stitch selector to select the buttonhole. Test your machine on a piece of scrap fabric to make sure your buttonhole function works, before trying to sew on your garment. If it does not work, then bring your machine in to your local Baby Lock dealer.
Dec 27, 2011 | Baby Lock BL1556
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
I can't find my manual and I need to know how to do button holes
You could try to locate a manual on the web or try sewing.about.com, there is lots of information on this website.
Sorry, I'm not familiar with this model machine at all.
But if it is an automatic buttonholer model, there is probably a special buttonhole foot in your accessory box? Is it a long white plastic device where you put a button in the back to get the correct lenth. If yes, then put it on the machine and there will also be a lever at the left side of the presser foot that you need to pull down. This buttonhole style sews the bar tack, then one side, the end tack, then the other side and works backwards from the starting point.
Now check your machine dial settings, there is probably a buttonhole icon?
You might be able to muddle through this way?
Feb 27, 2011 | Simplicity Denim Star SW210
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
I have a Singer model 9910 and am not able to make a buttonhole on the setting for #61. The buttonhole seems to be inserted properly and the foot is lowered but the machine just beeps and will not sew.
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
May 15, 2010 | Singer Quantum 9910 Computerized Sewing...
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
White Sewing 2999 Mechanical Sewing Machine Logo
512 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
