Question about Cell Phones
White screen halfway and horizontal lines
I cant see anything
  • Cell Phones Master
  • 573 Answers
Please change a new LCD (the screen). Hope it will be helpful to you by replacing a new one.,
Thanks for using FixYa!
Posted on Nov 01, 2012
2 Suggested Answers
  • 129 Answers
SOURCE: screen of my N73 has many lines that i cant see anything.
Dear.may be your LCD strip is moved from its place or LCD has broke down ,so if u can open ur mobile fone yourself then open it and check the LCD strip and press the LCD strip to plug it properly if it does not work then get a LCD and change. thanks
Posted on Feb 05, 2010
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
Tip
If Your screen shows a: white vertical line on a black screen or, a white...
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, carefully using your finger find the too hot transistor or, chip; or, use component coolant; spray the too hot component with a component cooler repower the TV, until the screen comes back to normal. To fix: apply white sylicone coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Garden
Tip
TV shows either: black screen with: white vertical or, horizontal line
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
St90 white line
Yes, the LCD is failing.
Nov 25, 2012 | Samsung ST90 Digital Camera
White screen on blackberry
i pressed my bb screen hard and then halfway through the page a white mark apeared and the horizontal white line. what should i do
Oct 28, 2012 | RIM BlackBerry Curve 8520 Smartphone
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Screen of my N73 has many lines that i cant see anything.
Feb 05, 2010 | Nokia N73 Cellular Phone
White horizontal lines appear in the screen
you may just need to reseat the cables. basically all you have to do is take the keyboard bezel off of the laptop and disconnect and reconnect the cables on the lcd. you usually do not need to unscrew anything but a pick would help. Just simply pry it off using a pick or small flatheadd80ef8a.jpg
Dec 08, 2009 | Sony VAIO VGN-CR220E/W Notebook
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Horizontal white lines
if you cant adjust the A1s then it sounds like the F.B.T. is up the swanny (faulty).
Jun 01, 2007 | Jensen Q2049J 20" TV
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
