Marantz CD48 No Disc - how do I clean the laser head?
After a period of storage without use, the CD player doesn't recognize the discs I insert. It says "no disc". I already cycled he power, tried other discs, and gently tapped here and there. thanks for any advice!
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
  • 1015 Answers
SOURCE: it is not reading the blank disks anymore
Sounds like that may be the case. You can buy one of those cd cleaning discs and try using that. or if you want to spend the time dis-assembling the recorder and use some rubbing alchohol and a q-tip to clean the laser lens. Otherwise not worth the cost to repair.
Posted on Oct 15, 2009
djcliff
SOURCE: Solve Problem Stanton S-550 dual Cd player
Same problamo........CD player mechanism needs replacement in my case!.....It could be a flexwire (a belt like flat cable inside your CD player connects motherboard and CD lense), check that out!
Posted on Nov 10, 2009
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
Front panel on machine just reads ..disc not finalised.what does this mean please?
Are the discs ones that you created (burned), someone else burned, or commercial discs? The message of disc not finalized usually appears when you put a CD or DVD from one unit into anther without closing (finalizing) the disc. The finalization step doesn't matter if the disc is being moved between computers with compatible OS versions (for example: XP through Windows 7). However, any other device will need this procedure completed.
Take the disc back to the unit (computer or other burner) where the disc was burned. If the computer uses Windows, put the disc in the optical drive. Open My Computer (Computer) depending on the OS by double left-clicking on the icon on the desktop. Right click on the optical drive and select Close Session.
If you created the CD on another machine, check the details for that device.
Note: you should double-check that the format that you burned to disc is compatible with this CD player. Not all models support MP3 files. On my own older CD player, I had to burn WAV files without gaps in a Disc At Once format to get the discs to play without skips.
I hope this helps.
(if the discs were commercial discs or have been finalized, I would expect a different error. In that case, I'd suspect a tracking problem and a "No Disc" error.)
Jun 15, 2012 | Marantz Audio Players & Recorders
Displays no disc when Cd is player
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
Jan 23, 2012 | Sanyo DC-DA1000 CD Shelf System
Player not reading disc , what could it be
Hello
Just clean the laser pickup unit lens, by inserting a disc cleaning disc. this disc an be bought from most of the electronics spare part selling shops at your town. If it doesn't help you, there is no other way than replacing its Laser Pickup Unit with same type and number. OK.
Jan 15, 2012 | Pioneer PD-F507 25-Disc CD Changer
Records entire church service & indicates time on display but when we finalize disc it immediately says bad disc or new disc
A laser beam on most (nor all) machine got a ''fixed'' lifetime. After some periode, the light beam get weaker and problem starts. First step would be to make the head clean, i do it myself with Qtip and alcohol make sure the eye is crystal clear, without any imperfection on it. Some times accessing the carrier is not easy, i'm not a fan of auto cleaning disc anyway. So after 2-3 or 4 years, and normal and hours are done with the machine, its normal that problems appear. Before you ask, its usually not economical to replace and ''tune'' a new laser unit. Also, a dvd recorder with hard drive would be a good investement. Look for brand name like pioneer...
Ciao, Dave.
Oct 08, 2009 | HHB BurnIt CDR830 CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
148 people viewed this question
 Grubhead
Grubhead
