Question about GE Refrigerators
Pfsf6pkx ge dumps 1- tray a day of ice only - GE Refrigerators
    Top Expert:
  • GE Master
  • 9,472 Answers
You will need a new "ice maker circuit board". Here is the part to order.
Posted on Nov 01, 2012
SOURCE: icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
Posted on May 01, 2009
SOURCE: Ice tray sometimes stuck when dumping off ice
I am an attorney near Philadelphia who is considering initiating a class action against LG related to the defective design of their ice maker. I have clients in different states who have had problems that LG fixed, but the problems re-occurred after the warranty expired. I've been advised by mechanics that leaks are inevitable based on the design. Apparently this is a design that LG had used years ago but had discontinued for a while because of leak problems. I'm usually on the defense side of product liability cases, but this seems to be a common defect. If you are interesed in such a suit, feel free to contact me at corrlaw@verizon.net. Law Office of John A. Corr, (610) 482-4237.
Posted on May 15, 2009
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
aasc
  • 1606 Answers
SOURCE: Ice maker quit dumping ice to the tray
You have a bad icemaker thermostat ( replace the whole icemaker ) or the temperature is not at least 5 degrees cold . You might check your coils to make sure they are clean (usually at the bottom from the front of the fridge ) only vacum or brush what you can get to as this will also keep the icemaker from harvesting .
Posted on Jul 11, 2009
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
Water dispenser in ge profile pfsf6pkx 1.2 year old fridge works fine, icemaker stopped making ice, no sound of water refill from maker, ice lock not on, recycled filter, any ideas before we spend $ ?
Have the same model and same exact problem. Did you find any solution? If so, pls post - willing to try anything before the $200 service call. Thanks and good luck on yoiur situation.
Oct 20, 2010 | General Electric PFSF6PKX Bottom Freezer...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
ICE IN TRAY BUT WILL NOT DUMP
This is a problem with the icemaker. You will need to replace it.
May 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice Dispenser on GE Profile PSS23MSTC does not work.
sounds like the ice is stuck together and the auger can't turn. remove ice tray and dump old ice new cubes should begin falling into tray after 30 minutes or so.
Jan 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
