Washer goes into wash mode when its suppose to spin out
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
  • 18 Answers
SOURCE: washer goes into unbalance mode
Check the springs and spring mounts,(might be broken or not on right), also could be something wrong with the balance switch (where the tub hits the switch).It could be mis aligned or defective. Check the springs first.
Posted on May 14, 2007
dididsaythat
  • 291 Answers
SOURCE: Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Posted on Aug 29, 2007
  • 10 Answers
SOURCE: won't hardly spin
the back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Posted on Feb 12, 2008
  • 33 Answers
SOURCE: kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: our washing machine kenmore elite stops spinning
"5d" is actually, "Sd." It means "Suds." If you pop the top on the washer (there should be some tabs along the front were the top joins it. Take a flashlight and check it out. Use a thin screwdriver, pop the tabs, and lift the top up. Once you pop its top, look inside the front panel. There should be a service manual there unless someone has removed it.) Once you get your service manual, you can join the rest of us Kenmore Elite owners in Kenmore Elite H*ll. If this is the Oasis machine, even though you paid a truck load of money for it, it's a piece of junk. The service manual is the most confusing waste of paper I've ever seen. Odds are, you need to replace either the top computer module (they're defective and were recalled) or the RPS. Check eBay for the best prices on these items. If you believe it's your computer module, call Sears--talk nice--and maybe they'll still honor the recall, which has expired. Once you get it fixed, sell it and get something less computerized because the next thing that will go out is your stator. This is the most cheaply built piece of junk washer I have ever owned. Once you look inside it, you'll see what I mean.
Posted on Nov 30, 2009
My kenmore model #110.42722200 washes but won't drain or go into spin cycle,it just makes a clicking noise.
this is caused by a faulty drain pump or broken lid switch tap the pump if it goes then replace it
Dec 26, 2015 | Kenmore Washing Machines
The spin cycle does not work. It will spin to wash and it drains.
Sounds like the electronic door lock mechanism is malfunctioning. It is supposed to enguage before it goes into the high spin mode.
Sep 22, 2011 | Frigidaire GLTF2940ES Front Load Washer
Have kenmore heavy duty 80 series about 15 years old. It will not go into spinning mode after washing mode or rinse mode as it is supposed to.. By fooling with the controls I can eventually get it to...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2010 | Kenmore Washing Machines
My washer is going through the wash cycle but when the spin cycle is supposed to start it doesn't spin
my washer is going through the wash cycle but when the spin cycle is supposed to start it doesn't spin
Mar 08, 2010 | GE Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Kenmore 80 Series Won't advance to spin
You will need to replace the timer. Let me explain why;
After the agitation cycle, the machine will enter a drain mode where the basket will not spin, only drain. After some time, the timer should 'pause' causing the machine to engage the spin clutch. The timer contact has become stuck, not allowing the pause, thus never entering engaging the spin clutch.
Jul 02, 2008 | Washing Machines
Won't hardly spin
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
