Question about Garmin nuvi 250W GPS Receiver
Some POIs are missing.
I just got my Garmin 260W and have been playing with it locally to get a feel for how to use it. I set my home location and that works, I used it to go to an unfamiliar area and that worked as well, but I tried to find several stores close to my home - Target, Kohls, Sears - and none of them were found. I even tried finding one of them when I was right down the street from it. What's wrong?
  • Garmin Expert
  • 343 Answers
Nothing.
Not all business's will show up. Try putting in their address's.
Also do you have the latest maps. New maps are released about every 4 months. I bought the life time maps upgrade for $99.
Or, you can buy new maps when you want, but the are about $80 each. Ouch on that!!
Posted on Jan 18, 2010
How to unlock the garmin nuvi 260w
  • 1
    Turn on your Nuvi 260W.
  • 2
    Enter the four-digit PIN you chose when you locked the device. If you have forgotten the PIN, proceed to Step 3.
  • 3
    Drive to your security location. When you reach your security location the Nuvi 260W will unlock automatically. If you forgot your security location or cannot drive there, proceed to Step 4.
  • 4
    Call Garmin to unlock your device. You need your receipt to complete the process. Call 1-800-800-1020 in the U.S., 1-866-429-9296 in Canada. See Resources for the Garmin support webpage.
  • Mar 05, 2011 | Garmin nuvi 260W GPS Receiver
    My husband and i spit up and he changed the password of my Garmin nüvi 260. I can't get into, is there away to reset it?
    You need to go within 30 meters of the Security Location that the GPS was set up, it will then unlock automatically..... most times its either Home location or Job location
    Oct 17, 2010 | Garmin nuvi 260W GPS Receiver
    Garmin nuvi 260w is not charging with car charger
    You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
    May 29, 2010 | Garmin nuvi 260W GPS Receiver
    How do I reset my home location on my Garmin Nuvi 260W?
    When your at a spot you want to set as home save it and name it Home. then it will be set as your home button.
    May 17, 2010 | Garmin nuvi 260W GPS Receiver
    I forgot my pin and I need to unlock it
    You have to go to the orig location you programmed your number. It uses the coordinates of that location in memory as a "Home" See below.
    The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location.
    To set the Garmin Lock on the device:
    1. From the Main Menu, touch the Wrench (Tools) icon.
    2. Touch Settings.
    3. Touch Security. (you may need to touch the down arrow button)
    4. Touch the tab labeled Off next to the Garmin Lock heading.
    5. The nuvi will prompt you to enter a four-digit pin number.
    6. Enter a four-digit code as your pin.
    7. Re-enter the four-digit pin.
    8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
    9. Set the 'Security Location' by touching Set.
    The Garmin Lock has now been turned On.
    Dec 25, 2009 | Garmin nuvi 260W GPS Receiver
    Garmin Nuvi 260w not recognized by computer
    Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
    It worked for me and my Zumo550
    Goodluck
    Auke
    Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
    My garmin is missing software
    Goodluck
    Auke
    I need to change from Spanish to English on my new Garmin 260W
    That's funny. Guess you need to brush up on your Spanish!
    Here's how to fix assuming you have a 260 or 260w:
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
    To change the text language:
    1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
    2. Touch the Gears icon
    3. Touch the down arrow
    4. Touch the second option from the top1
    5. Touch the middle blue box on right
    6. Touch the up arrow until American English appears2
    7. Touch American English
    8. Touch OK
    9. Touch Back
    The device should be in selected text language.
    Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
    Note 2 - If American English is not the language needed, please selected the desired language
    Mar 01, 2009 | Garmin nuvi 260W GPS Receiver
    GARMIN 260W
    Hi It is more important to know how to add POIs. Here is a simple tip:
    1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
    2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
    I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
    3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
    Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
    4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
    In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
    Cheers
    Feb 13, 2009 | Garmin nuvi 260W GPS Receiver
    Garmin nuvi 250W GPS Receiver Logo
    51 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
