Question about Onkyo TX-SR606 Receiver
Clicking noise from Onkyo TX-SR606 during television broadcast
The receiver clicks repeatedly between various audio modes (Mono - Digital 5.1 - Stereo - Mono - Digital 5.1, etc.) during which time no sound is heard. This can happen at any time, and lasts between 1-2 seconds to 10-15 seconds. Quite annoying. Could it be the HDMI cable connecting the Onkyo receiver with the Samsung Time Warner HDTV cable box? Any suggestions?
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Posted on Jan 06, 2009
Onkyo sr606 service manual
Go to Onkyousa.com, move mouse cursor to support, click on owner's manuals, click on receivers, click view archived receiver models, click TX-SR606 (both"quick setup" and "HTS 7100 for the full manual").
Oct 18, 2012 | Onkyo TX-SR606 Receiver
My Onkyo TX-SR606 will not turn off, will not adjust volume, will not change modes, will not do anything but stay "stuck" on cable/satellite at volume 33. It will not reset. I unplugged it, waited, and...
contact onkyo and ask for a disc that you use threw the cd player via a toslink . The disc will upgrade your avr ,thus overwriting any problems you had. My tx-sr705 had an issue with popping during blu ray playback while the dts-master audio was being used. I got a disc that upgraded the chip that utilizes the codec's.
Aug 14, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Apr 27, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Can someone tell me what the audio setting on the Onkyo TX-SR606 should be when the PS3 passes the signal as full multi-channel. My receiver always seems to say something different i.e. Dolby Digital or TV...
If you're running an optical cable from the PS3 to the receiver, best quality would be through the Dolby Digital, because that broadcasts in 7.1 HD Audio Format. There should be a way to get a default setting when the optical input is detected in your receiver.
Turns off if sound level is increased
there is a protection circuit kicking in.
First thing to check.....Verifiy that all speaker lines are in correct polarity.
+ and gold or writing/stripe on cable.
Check this all the way around and if the sub is a line in sub,, check that also.
You really should just unplug them all and start one by one.
If you cannot get to the wires or its too hard to access,
hold your hand 1/8 of an inch from the woofers. they should be kicking out, not pulling in.
Could also be a blown woofer somewhere in the system.
Hope that helps!
Charles
Jan 09, 2009 | Onkyo TX-SR606 Receiver
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
Onkyo TX-SR606 Receiver Logo
581 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
