Question about RCA F27440 27" TV
Hi I am having trouble getting my DVD player to work with my RCA F27440 TV. It worked fine with my other TV. Can you help?
  • talkwithbonn Jan 04, 2009
    It is a yellow, red, and white plug
  • Jeremy Awbrey May 11, 2010
    How are you connecting it? S-video or composite video (yellow plug)?
  • 20 Answers
If there is not a TV/Video button on the TV I believe that RCA uses channel 00 (zero zero) for the video input.
Posted on Jan 05, 2009
Rca 32 inch has picture but no audio dvd player works fine when plugged in.
Hello
If your TV has audio and video when connected to DVD player, its sound filtering circutary in RF[Radio Frequency] stage is in trouble. You yoursef cannot detect and repair it. You must get the service of an experienced service personal. It needs skill, ability to follow the schamatic diagram, and more patience.
If there is no sound when DVD player connected, the speaker of your TV has in trouble. It can be replaced by you, after unpluging your TV from mains socket, open its back cover, screw out it from its position and go for a similar type and impedence. Just refit the new and give the 2 connections. That is all. Ok.
Oct 21, 2010 | RCA F32649 32" TV
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Television trouble
Might it be that you changed the input? Try pushing the input button on the remote.
Hope it helps...
Mar 04, 2008 | RCA F27442 27" TV
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
RCA F27440 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
