Question about Hardware & Accessories
Geyser timer stopped working - Hardware & Accessories
  • 5,089 Answers
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Posted on Nov 01, 2012
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
Sep 19, 2014 | Hardware & Accessories
Geyser outlet pipe overflowing, is i likely that the geyser is going to burst
no that is not your problem it's your stop valve that is the problem it's not sealing properly so you need to replace it
Dec 11, 2013 | Vehicle Parts & Accessories
Marley md26
A standard 'Geyser' (water heater) timer is quite capable of controlling the two heaters.
Nov 22, 2013 | Heating & Cooling
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Oct 31, 2013 | Hardware & Accessories
Hardware & Accessories Logo
348 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
