Question about Whirlpool LEQ8000JQ Electric Dryer
Whirlpool dryer ignighter not glowing
I have an old whirpool dryer, looking through the inspection hole, I can see the ignighter is not glowing. pulled it out,has 85 ohms.appears to be o.k. no voltage going to it. have no schematic.
  • 163 Answers
Hi!!! you might have a timer problem.Good luck..
Posted on Jan 04, 2009
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer is not heating.i looked in the peep hole and could not see the ignighter glowing
That's the problem, a bad IGNITER. Easy to replace and available at all Appliance Parts Stores.
Nov 27, 2009 | Kenmore Dryers
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Model DLE2516W, will not heat up. lint catcher is clean, but unit only puts out cool air. it is only 2 years old.
check the pipe that goes outside make sure it is clean also. if so there should be a door or panel one the bottom of the dryer remove and see if this area is clean also, if so with the panel off start the dryer and see if the ignighter glows red . the ignighter mast reach a certian glow before the gas valve will open this could be the problem. let me know how this goes
Aug 16, 2009 | Dryers
My whirlpool dryer igniter glows but doesn't stay
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Whirlpool LGR3624JQ Gas Dryer
I have a whirlpool estate gas dryer. I am not getting 110 volts to the ignitor. Therefore the ignitor won't glow. any advice? John
just replace the ignighter it dont get 110 its the way its designed for the safty valve if it dont glow 99percent of the time its bad and even if it does glow it still can be bad as its has to use so many amps for the safty valve to open
Jul 13, 2008 | Dryers
Front load 4years old not hot
Attached to the lint trap housing are two devices. One is the thermostat, the other a thermal fuse. Check each for continuity. The igniter will not glow if either device has failed.
Jun 22, 2008 | Kenmore Dryers
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
