Question about Kitchen Ranges
Bosch Extractor Hood
A short while ago we had our kitchen re-fitted. At that several Bosch appliances were installed, one of them being an Extractor Hood. the model we had fitted is a DWA09W451B. We are currently redecorating the kitchen walls and would like to remove the curved glass panel from the hood. We have removed the trunking above the unit with no problem. It then appear the glass panel is held in situ with two plastic clips (one on each side). To understand how they are fitted I tried reviewing your download copies of instruction manuals, but the system was not working. i manage to get into the Spare-Part section and it appears from the diagrams that the clips slide onto a cutout into the glass. However I cannot get the clips to move. I am conscious of not wanting to break the glass panel and ideally not to damage the clips, however I am not certain how to remove the clips. Therefore could you please give me details how I can remove the glass panel / clips as appropriate.
Cyril J
  • 45 Answers
SOURCE: I need assistance on how
usually you replace the whole fixture ,popping it out and cuttung wires then popping new unit in
Posted on May 16, 2008
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
SOURCE: Removal of cooker hood to locate electric plug
Thank you for your letter, we had to dismantle the whole cooker hood to get to the electric plug.
Thank you.
Posted on Jan 19, 2009
  • 72 Answers
SOURCE: extractor hood
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Posted on Dec 27, 2009
leedavidian
  • 1420 Answers
SOURCE: I have a Bosch Hob
what model do you have and/ or series, Thanks, Lee
Posted on Jan 17, 2010
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
Hi My extractor hood in the kitchen has a hose that goes into the kitchen roof then out through the roof vents. The problem is that all the cold and wind comes back down the hose and makes the kitchen very...
You need to install a damper. It sounds like your vent now just vents into the attic and out the attic vents. If that is the case, or even if it vents directly to a roof vent, you can install a damper that only lets air flowe one direction.
rewilliams_2068_131005279
springload.gif Here is just one source of many that you can purchse dampers from.
http://www.rewci.com/416splobada.html
The damper would be installed in the exhaust duct. If your vent pipe is connected to a roofmounted vent, you can replace the vent with a dampered vent.
Aug 30, 2009 | Bosch 22 in. PCD685F / PCD685D / PCD682D...
Faulty electrolux kitchen extractor unit
good day,
hope this link below will solve your problem.
kitchen
Jun 07, 2009 | Fat extraction holder Kitchen Hood
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Painting
Hello there, You can paint your kitchen hood with special paint (appliance epoxy), but you might want to take it to a professional. It is not a simple job to do. have fun!
Aug 07, 2007 | Bosch (DKE9465EUC) Stainless Steel Kitchen...
Extractor hood
Aug 07, 2007 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
