Question about Troy-Bilt Tb154e 9-Inch 6.5-Amp Electric Garden Cultivator/Tiller
Troy bilt electric cultivator won't start
2nd time using it....it worked for about 10 min and then shut off. Cant get it to start back up.
  • 9 Answers
SOURCE: engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Posted on Jun 28, 2009
  • 1584 Answers
SOURCE: I have a Troy Bilt Bronco 5.5 hp that will start
Sounds like fuel starvation
Check / remove carby / strip down / check for blocked jets for contamination.
Check spark is present.
Is correct heat range
Posted on Mar 17, 2010
  • 26 Answers
SOURCE: troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Posted on Oct 07, 2010
  • 3074 Answers
SOURCE: 5.5HP Briggs and Stratton engine
spark plug or the coil/magneto
Posted on May 07, 2011
  • 4 Answers
SOURCE: I have a 4 cycle Troy Bilt TB144 cultivator and
hi remove pull cord and replace the pins
Posted on Sep 03, 2011
Troy bilt G C 720 manual
I have a new troy built garden cultivator (modelGC720). It won't turn and the motor stalls when the trigger is pulled. Should I return it or is there a easy fix ?
Feb 13, 2013 | Troy-Bilt Troy Bilt Gc720 Trimmer Plus...
My neighbor's gardenway snow thrower by troy bilt electric start won't start.
check the oil level. There is a safety device in a lot of small engines that will either kill the motor or not allow the motor to start if it is low on oil
Dec 30, 2012 | Garden
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
Troy tiller won't crank
is it electric start or manual pull?? remove pulg and see if it cranks over. Could be mouse nest under recoil cover or under flywheel, could be rusted to the magnets. need more info. Oh yea make sure belts are not holding you back remove them or make sure they are loose.
May 05, 2011 | Troy-Bilt Pony Garden Tiller
I just purchased a 2011 big red troy built tiller and used it the first time today and it just starts acting like it is not getting gas and starts sputtering and dies
problem with a lot of small engines no running right is the gas we have to use these days (ethonal) they were not made to use that gas
Mar 12, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troybuilt cultivator/edger won't start
There are two starting procedures - initial starting after long storage or running out of gas calls for squeezing the bulb (note - squeezing the sides together - not pressing the bulb in) 6 times, poulling cord up to 10 tiimes, rapid pull. If that doesn;'t work, wait 15 minutes, do not press bulb, but pull cord 10 times again.
Normal starting after first use and w/gas in the tank calls for 2 presses of the bulb.
I found that I was not priming the engine well, but also it should not be as much of a pain as it is. I still am successful in starting on every third attempted use, get frustrated and say %*&% it most of the time. These things are made by MTD (for Troy-Bilt) and that, in my experience, stands for Machine Typically Dead.
Hope this helps.
Apr 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy-Bilt Tb154e 9-Inch 6.5-Amp Electric Garden Cultivator/Tiller Logo
332 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
