Question about Singer 5050 Mechanical Sewing Machine
Red light comes on when pressure foot is down
I've only used my machine a few times, and when I went back to use it the red light on the start/stop button comes on if the pressure foot is down. Of course, I imagine the machine is made to halt movement if the red light is on. Can anybody help?
  • connieloman Jan 04, 2009
    amachael, thanks so much. That did it!
Is your bobin winder thing on top pushed to the left? If it is pushed to the right - the machine will not allow you to start sewing.
Posted on Jan 04, 2009
My machine stop working even though the light comes on it stay red when the pressure foot is down.
Please provide a make & model. We can't do much to help without more information about your machine.
Aug 03, 2016 | Sewing Machines
Stop start button is not turning green when I put the foot down
Is the foot correctly attached? Is the machine clean? Bobbin winder on or off? Try turning it off again crisply.
Feb 25, 2014 | Juki Hzl-K85 Computerized Sewing Machine
Toyota sp100 sewing machine - can't lower foot pressure on clothing
Berend: Thick fabrics require a longer stitch length. If the longer stitch length doesn't work check your attachments for an Easy Feed foot (It sort of mimics a walking foot.)
Dec 06, 2012 | Sewing Machines
Problems with foot pedal light
sounds like there is a design fault, I suggest if you can take the
machine back and get a different brand of sewing machine.
I've been sewing for over 25 years and I would put up
with that kind of sewing machine.
probably a computer problem.
Nov 15, 2012 | Sewing Machines
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
I can't start to sew on my 830. The foot control is recognized(the start/stop button light goes off when I press the foot control), but does not make the presser foot come down. It worked 15 minutes ago...
If you lower the pressure foot before you press the foot control does it sew then? If so, then some how in your setting menu you auto pressure foot setting has gotten turned off.
Apr 23, 2011 | Bernina Artista 180
I have a janome 234D overlocker and when I start sewing the first thread (red) comes unthreaded....
This is a tricky problem, without being in front of the machine.
1. check that thread comes thru machine with ease (pressure foot up)
2. rethread machine starting with lower looper (right hand thread)
3. make sure that when pressure foot is down there is some tension on the thread, (sometimes stuff gets stuck in the tension discs)
4. if that fails, suggest having a repair service check it out for you.
Apr 02, 2011 | Janome Memory Craft 4000 Sewing Machine
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
Singer 5050 Mechanical Sewing Machine Logo
188 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
