Question about Sony RDR-VX500 DVD Recorder/VCR
Disc Error, Will Not Read Any Disc New or Old
After Loading DVD into Player it makes a low pitched clicking sound at approx. 30 beats per min. After a minute or 2 it ejects the Disc and displays "DISC ERROR". I've tried newly purcahsed DVD Movies and get the same reult.
  • 2 more comments
  • Anonymous Feb 21, 2009
    Same problem here!!!!
  • Anonymous Mar 17, 2009
    When I insert a disc for recording, it says it's loading the disc, then it says it needs to format the disc, then it works on it for a few minutes then spits out the disc with the error message: "This disc cannot be read or formatted."
    I have tried all the disc formats that the player/recorder claims to be able to use, but no discs work with it. I have cleaned it with a cleaning disc. It used to work fine, then it worked sporadically, now it won't accept any disc at all! It does play commercial DVDs, however.
    HELP!
  • Anonymous Mar 25, 2009
    exactly the same issue :-(
  • Anonymous May 12, 2009
    get disc error formatting o trying to play previous recorded movies it happened suddenly disc erroe message then ejection
DVD players are ****!! This is my 5th time buying one. It's like the industry is running a big scam because that know that soon all movies will be digital mp3. All of my players give me the same error!!
Posted on Jan 04, 2009
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
Loading Problem
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
May 25, 2009 | Philips LX3600D System
Unreadable discs for xbox360 after playing them for approx 30 min
This happens when the laser is set too low power, ideally the laser should be set to around 280ohms where yours may be at 400 or thereabouts., replacement lasers will fix this problem or if its possible maybe a re-alignment would also make it work again. Replacing the part is very easy and you can find the lasers on ebay for around £15. If you get stuck and need help we offer a full repair service www.fixmyconsole.co.uk
Dec 25, 2008 | Microsoft Xbox 360 Console
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Disc Error
Try to clean the read laser and the laser pickup, by using a DVD cleaning disk. If this does not work you may have a misaligned laser or pickup.
That may sound like a canned response and it is, however it is a good start. I would also check the format of the video on the DVD-RW, and make sure the DVD player is set to display that format.  Also might I suggest that you try the documented Disk loading instructions. I know that sounds stupid, but I was working on a customers DVD player one day and I downloaded the manual, and I was shocked to find out that I was not following the recommended loading procedure, once I did that all of the disks worked (stupid? yes, but that's how things are now).
As I said try to clean the pick-up and laser, check the format of the DVDs, and then follow the recommended loading instructions.
I hope this helps
Thank you,
Shuttle83
Apr 23, 2008 | Sansui VRDVD4005 DVD Player/VCR
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
At loadup.
check your disc's that it's not putting a mark on them...
sounds like the laser is hitting the disk trying to get it to focus,
thus it's either the spindal is to low or not moving or the laser is week or not in the correct position
Dec 04, 2007 | Apex Digital AD-1125 DVD Player
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony RDR-VX500 DVD Recorder/VCR Logo
331 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
