Question about Sony KP-57WS510 57" Rear Projection HDTV
8 Flashes, Changed Flyback... still no good.
Ok, I was getting 8 flashes. When you power the tv on you would hear the sound for a second and it would power off and flash 8 times.
I unpluged the tripler and it still wouldnt come on. Since it wouldnt come on I assumed it was the flyback. I found a company locally that sold tv parts and bought the flyback. Came home and soldered that one on and it has the same 8 flashes. The only thing is that when I got home. I noticed the flyback he sold me had a different part number than the one that came off the board. New flyback is 1-453-285-21. The one that was in it originally was 8-598-955-32. The guy said it shouldnt matter. I am wondering if maybe the new flyback doesnt output the right voltage or maybe there is another problem. I am thinking of buying the whole d board... what do you think?
  • 3 Boys Dad Jan 13, 2009
    TV turned off sudenly. When turned on it switches on ,then off with 8 blinks.
    I replaced the FBT ,same problem.
    Sent D Board and G Board in to PTS electronics ,no Fault found.
    Sent complete chassis(all the boards) to PTS ,No Fault found
    What could it be?
    Problem Solver:
  • 11 Answers
Try the High Voltage block first. Very common failure.
Posted on Jan 04, 2009
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
KP-57WS500 8 blinks will not power on
8 blink error code is usually indicating that the HV transformer ( Flyback) is faulty on the D board. You can get a replacement flyback at the following link with free tech support to explain how to replace it. Heres a link to the correct Flyback for the KP51-65WS500 model sonys.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328541/cName/flybacks
Jan 04, 2009 | Televison & Video
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
Dec 29, 2008 | Televison & Video
Sony KP-57WS500 cutting off
Since you get a picture for a while, it is unlikely to be either the flyback or the horizontal output transistor as those would not allow a picture for any amount of time. You would jsut get the 8 flashes. This sounds more like an over voltage problem that could be in the regulator circuit. I'll look up the service manual on this one and get you more details.
Dan
Oct 14, 2008 | Sony KP-57WS500 57" Rear Projection...
Standby flashes 8 times
Flyback is defective on the D board. You can get a new replacement flyback with free instructions at the following link, or they also have the new replacement D board for your model also. Heres the link, just click on the Sony parts category.
Aug 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KV-32S66 standby timer led flashes constant, slow; no picture
You could try touching a soldering iron to each joint, but if tv had perfect image before turning off, could be a bad flyback. Cheap part and easy repair BUT must know how to discharge any high voltage if any stored in capacitor of flyback. Might be a good repair to take in to have a pro fix it.
Apr 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Green Flashes - Shuts off
Sounds like the green picture tube is defective. To confirm you can take the front grille and door off and tap the green tube lightly with something plastic, and not to touch any of the adjustment controls to confirm.
Apr 12, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
