Question about Dishwashers
Error code 81 - Dishwashers
  • 14,384 Answers
WhAT'S THE BRAND AND MODEL NUMBER?
Posted on Oct 31, 2012
System wont do anything
When the self-diagnosis code C-81 displays, an internal problem has occurred with the HT system and will require service. Click the Repair & Status link on this page for available service...
Above is right from the Sony site. Get your wallet out and call the repairman.
Apr 18, 2014 | Sony DAV-C450 System
SEVER EROR 0X9010001
Was the error preceded by 81:01 or 81:11? That is the format for the actual error on a 500 series plotter.
If so then you have a Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
Carriage Belt if it is frayed or worn out, if it is good then
Replace the Encoder Disk Assembly.
Sep 22, 2013 | HP DesignJet 500ps InkJet Printer
Toshiba 720 error code 447
poor connection fuser drawer
go to this site to get error code listing
http://fyi.toshiba.com:81/KB/file_uploads/8535/TSB-1002.pdf
Jul 10, 2013 | Toshiba e-Studio 720 Copier
I have a 93 gmc z71. Its been running really weird. It has no acceleration and its been shaking bad at low speeds. All plugs, coil, distributor, rotor have been replaced. New computer as well. Used an obd1...
I'm showing code 72 as being a problem with the vehicle speed sensor, and code 81 as a 2nd - 3rd shift error in the transmission.
Have you replaced the plug wires, and checked the base fuel pressure ?
May 05, 2013 | Cars & Trucks
I cant find the area code of japan
Hello the area code for Japan is 81 and various areas / counties within Japan are // below -- Ray Japan City Codes Cell Phones +81 090 + eight digit number Nagoya +81 52 Naha +81 98 Okinawa +81 98 Osaka +81 66 PHS phones +81 070 + eight digit number Sapporo +81 11 Sasebo +81 956 Seto +81 561 Tachikawa (Tokyo) +81 425 Tokyo +81 3 Urasoe +81 98 Yokohama +81 45 Yokosuka (Kanagawa) +81 468
Jan 11, 2011 | Computers & Internet
Error code 81? how to fix.? what is problem?
Hello, I just figured out what Error Code 81 means in the Lavazza LB2210 espresso machine. This code indicates a jam in the cup mechanism. To fix this issue you just need to remove the front cover (remove two screws) and then look for any jams in the roller section of the unit located in the center. In my case the cup was jammed at the upper left section of the roller mechanism that is used to eject the cups. I had to pull out the used cup and then reassemble the unit (at which point everything was fine).
This issue happened despite the use of Blue cups so if you see this message you should look for a jam to clear.
Sep 27, 2010 | Lavazza LB2210 Aluminum
Fax sending problem - error code 81
Greetings John,
This error is for 81 Z no user profile for pre-process.81 error indicates that a temporary error has occured while testing. If cycling the power does not solve the problem you should replace the formatter board.
Also It could be a problem with the power supply or DC controller. There may fluctuating power issues with the formatter. Also did you replace the network card after replacing the formatter or did you use the same network card that was replaced before the formatter was replaced. It may be the new network card may have been damaged by the old formatter and gives the same problem now, and using the damaged network card may have messed up the formatter again. To test this replace both formatter and network card together.
Regards,
TechSup1
May 01, 2009 | HP COLOR LASERJET CM3530FS UP TO 31/30PPM...
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
How to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Dec 20, 2008 | Sharp AR-M455N Copier
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
