Question about Whirlpool Washing Machines
Washer stopped, wet clothes inside, door locked, --- in message
  • 44 Answers
Unplug for about 10 minutes and then plug back in and try to start it.this will reset the micro computer in it.
Posted on Oct 31, 2012
  • 1314 Answers
SOURCE: POWER OUT DOOR LOCKED
if you pull the bottom panel off and reach up the side where the lock is you will feel a tear shaped tab at the bottom of the door lock pull it down to un lock
Posted on Sep 11, 2008
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
  • 530 Answers
SOURCE: Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Posted on Jan 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: hi, i have a kenmore
Drop front panel
open pump sump
clear objects.
Retry
Posted on Jan 08, 2009
  • 34 Answers
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Posted on Apr 30, 2009
My Siemens Extraclasse 1300 Washer/dryer just stopped as though no power. Fuse is ok.
check door inter lock by putting mech on leave 4 five mins go and try to open door imeditlaty if if opens straight away its the inter lock
Feb 22, 2015 | Siemens Washing Machines
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wash cycle stops with 1 min left and clothes are sopping wet
dl mean door lock system fail. may be lose connection on your door lock or control board.
May 23, 2009 | Washing Machines
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Apr 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
