Question about Dewalt DW303 Heavy Duty 65 Amp Reciprocating Saw with 10 Free Blades
Blade doesn't move (reciprocate)
Motor makes noise as if turning, but blade doesn't move
  • 44 Answers
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Posted on Oct 31, 2012
3 Suggested Answers
  • 436 Answers
SOURCE: cannot put blade into 310
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
Posted on May 25, 2011
  • 2006 Answers
SOURCE: How do I remove a broken blade on a reciprocating
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Posted on Jun 20, 2011
Snow joe6200j blade does not rotate
First, does the motor make noise like it is spinning. If so, it is probably a broken drive belt between the motor and auger. The attached link shows how to replace the belt (pages 11-12). If the motor makes a humming noise but nothing is moving, something may be jammed. Bring the machine inside to melt any ice, and inspect the auger and belt. If there is no noise, make sure the extension cord has power by plugging something else into it. If there is power, you my have a bad switch or a burned out motor.
http://www.snowjoe.com/docs/SJ620%20621%20Manual_ENG(2).pdf
Feb 28, 2014 | snowjoe 18" 13.5 Amp Electric Snow Thrower
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 19, 2013 | Husqvarna Garden
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hercules Helicopter doesn't move forward much
My Hercules is a 3 channel heli,and I will try moving battery forward. On my SYMA s107 I turned the back blade upside down and got a dif style blade. It now goes Forward Great.
Jun 01, 2013 | Toys
Band saw very noisy
This could be several things. To find the noise, unplug it, open the covers and turn the wheels by hand to see if you cand find where the noise is coming from - this might help you find the source of noise if it the blade is hitting something it's not supposed to. If that doesn't find it, you might try removing the blade entirely and running the motor to see if the motor is the source of the noise. If that doesn't find it, you might try putting a different blade on. Good luck.
Oct 21, 2012 | Saws
Whirlpool washer problem spinning
If it makes noise but moves, it's your motor - it it doesn't move at all, it's the belt. Noise and won't move, get a new washer. Check the BELT first - that usually is the problem.
Jul 22, 2012 | Washing Machines
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
My fridge is making a lot of noise. It does not stop. What might the problem be? Model# 2539668010 Serial# BA62202425
This is a basic no frills refrigerator so that things that can make a lot of noise is limited. And where you say it doesn't stop, then it is most likely a fan. You have two one in the freezer compartment that could have accumulated some ice on the blades which could through it out of alignment. So it might be hitting the sides of the case.
The other fan is underneath your cabinet, and blows air across the compressor, and condenser coil. If there is a lot of lint or debie in this area then the fan blades could be come coated and then the out of balance condition could cause noise.
If a cleaning doesn't fix the problem then you will probably have to replace the fan blades and motor.
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
I bought two Beacon Hill Hunter ceiling fans recently. I bought them because of the promise of "whisper quiet." To my great disappointment the motors are loud. I have one on in another room...
It may not be the motors making the noise, but the blade irons that are attached to the motor are loose and are rubbing the housing.
To confirm this, turn the fans OFF. When the blades stop turning, use a step ladder to reach the fan blades and the blade irons. Using a Phillips head screw driver, attempt to tighten each blade iron screw (2 in each iron), that screws into the fan motor spindle. I suspect, you'll find one or more loose. Especially if, the lock washer wasn't installed on each screw.
Hope this helps you solve the problem. If it doesn't, contact Hunter per the instructions in your Owners Manual. As there is a slim chance that there is a manufacturer's defect involved.
May 06, 2011 | Hunter Heating & Cooling
Dewalt DW303 Heavy Duty 65 Amp Reciprocating Saw with 10 Free Blades Logo
728 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
