Question about Drills
Battery Operated Screw Driver Catalog #9018
We have a battery operated Black & Decker screw driver and have no manual. We would like to know how to open the screw driver to replace the batteries. Right now it is not working.
badenhop
  • 44 Answers
SOURCE: Won't charge fully
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
Posted on May 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: How much does the Black & Decker HPD14K-2 weigh w/battery
10 pounds according to the Amazon listing, with a shipping weight of 10.2 pounds.
Posted on Dec 17, 2009
SOURCE: My old black & decker power screw driver will
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Posted on May 07, 2010
  • 178 Answers
SOURCE: how do I change the
The black collar should slide forward, allowing for the removal and insertion of bits.
Posted on Nov 25, 2010
SOURCE: MY VPX 1101 SCREW DRIVER TRIGGER IS INTERMITINTLY
I found that squeezing the trigger at the very top would make mine work every time. Problem is the trigger does not have enough travel to depress the switch far enough. If you were to epoxy a thin plastic "shim" where the triger meets the switch, problem solved. I am assuming yours suffers from same fault as mine .
Posted on Dec 21, 2010
Black & Decker battery operated weed eater/edger not working at all.
you probably need to take the base apart ,mine had a loose wire on the motor on the end of the shaft,about ten phillips head screws ,there is one screw on the gaurd,good luck
May 31, 2012 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker LITHIUM CHARGER 14.4v to 18v . 90539541. fits A1518L, HP1884L
could be either one. Have you tried another battery? If not I would recommend taking BOTH in for inspection. They have a scanner that can detect if the battery has a problem. If you need to find a service center close to you go to dewaltservicenet.com and they have a locator. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker 14.4v Cordless Lithium...
How do I change the screw drivers on the black & decker power screw driver?
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
Need a battery for vpx tools
There is one on ebay, just type in black and decker vpx. 27.99 is the price. take care
Sep 03, 2010 | Black & Decker VPX1101X Vpx 7 Volt Screw...
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
May 10, 2010 | Black & Decker Black and Decker Mm575 18"...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
Chuck removal
There is a screw in the bottom of the chuck. It has a standard thread. Clamp the chuck in a vise, find a screw driver that fits as snug as possible, to prevent stripping the screw, remove the screw and pry off the chuck. An impact driver will simplify the removal, if one is available.
Jul 06, 2009 | Black & Decker Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
