SOURCE: my kenwood ddx616 indash keep showin DC OFFSET ERROER?
You could have a speaker wire or speaker tensile (flex) lead that is shorting to ground, on a floating ground BTL head unit (all that claim 18-25 watts RMS per channel) all 8 speaker wires are always floating at about half of the supply voltage, IE if the voltage is 14.4 with the engine running the speaker wires will all measure about 7 volts to ground.
The flex leads are the wires on a speaker that go from the terminals to the cone.
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V)
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
