Question about Delta 36-979 10" Left-Tilt Contractor's Saw
Wiring diagram for delta table saw model 36-979
Wiring in new switch
rowdy45176
  • 2176 Answers
SOURCE: A Delta 10
Found it. Follow me closely. Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number, on the next page click on the breakdown type 3, USE the numbers on the left. Next look down after the schematic comes up and under instruction manuals use the last one (EN) click on it once move your mouse and click again then go back and click on it again, it will then bring up the manual. I don't know why you have to do it that way but most of their manuals you have to. The manual is about 20-25 pages long. Let me know if you have trouble because I had a little and if I have helped answer your problem would you please rate my response accordingly and Thank you.
Posted on Jun 06, 2009
protek480
  • 1714 Answers
SOURCE: I have an older Delta Contractors Table Saw but no
Go here:
http://powertool.manualsonline.com/manuals/mfg/delta/delta_saw_product_list.html
Posted on Jul 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Posted on Dec 08, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
  • 332 Answers
SOURCE: I have a delta 36-600 table saw and i keep burning
What is your voltage going to the saw
You may have a high voltage issue
Posted on Mar 14, 2010
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
Wiring diagram. delta 36-220
There wouldn't be much of one as this chop saw circuit is quite basic. I found the manual for you.
Jan 07, 2012 | Delta Saws
Changing volage on table saw
usually on the back of the plate where the wires go into the motor there is a wiring diagram for changing the voltage. UNPLUG saw first before removing the plate. Let me know if you need more assistance and I will try and help
Dec 30, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
Just need the wiring diagram for swtich and reset button
It is the basic.....
Green to groung.
Black to and from switch to motor.
White to motor neutral connection (while colored connection)
reset between switch and motor.
Sep 18, 2009 | Delta Saws
Received new switch and have an extra red wire which i believe is hooked up to the breaker on the saw. Is there a switch for a 7770 saw type with a post for the red wire
The 7770 model has a type1 and type 2, at least. (see here.) If you choose one of those models, you'll be able to access an exploded parts view and list for your saw. Since there are a couple of types, there had to be more than one switch available ...(see here.) but today I wouldn't count on it.
Go here and you'll be able to find a 770 manual (parts bulletin) with a wiring diagram on page 7. The only red wire I see there goes into a wire nut with a blue wire. Could it have pulled out? That's the best info I can offer, and I'm not sure it applies to your scenario.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 10, 2009 | Delta Machinery 10" Professional Radial...
I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Mar 28, 2009 | Saws
On/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Nov 02, 2008 | Saws
Delta 36-979 10" Left-Tilt Contractor's Saw Logo
191 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
