Question about Gateway GT5220 PC Desktop
Desktop screen freezes up when I 'right click' mouse on any ico
I have had the mouse for quite some time and it worked nicely. Recently I wanted to download some pictures to my Webshots program and was informed that I had to upgrade to a new Webshots; I tried that and had nothing but problems with Webshots.
I wanted to get rid of the newer version of the Webshots program, but still keep the older version. I had the older version for quite some time so decided to restore my computer to before I upgraded the program. (about two weeks ago)
Everything worked fine except: When I start up my computer to the desktop, I cannot 'right click' any icons. If I try to right click any icon, everything freezes up and I have to shut down my computer manually.
After shutting down the computer, I can again start normally to get to my desk top. I can now 'double click' on any icon and get to any program I want; once I'm out of the desktop and into any program, I can now 'right click' and everything works.
P.S. Problem: Right Click on any desktop icon freezes up the computer--don't know why.
P.S. If you can help, it would be very much appreciated
Sincerely, Mel C. Luethmers
mcluethmers@yagoo.com
P.S. I'm from St. Cloud, Minnesota and it's snowing like hell
    Problem Solver:
  • 11 Answers
This sounds as if there is a problem with Webshots corrupting a specific dll file in the Windows system. I hate to say this, but that usually means a complete reinstall from scratch. I would recommend trying to backup all of the files and reinstall windows.
Posted on Jan 04, 2009
How do i add gmail icon to task bar
What version of windows are you using? Windows 7 you can create a shortcut to your gmail account on the desktop. Download and save a Gmail Icon file (should be .ico from somewhere like http://findicons.com/search/gmail) then right click on the newly created shortcut on your desktop, choose properties, choose change icon under the shortcut tab, browse to where you icon was saved when you downloaded it and click on the file [your shortcut icon should now display your new icon]. Next click on your desktop shortcut holding your right mouse button and drag it to your task bar and release the right mouse button when pin to task bar is displayed.
Jan 19, 2015 | Computers & Internet
Touch screen keeps freezing
Does the screen also freeze if you are using a mouse instead of touching the screen? If the freezing still occurs, then the problem is NOT the touchscreen. If it works OK with the mouse then you may need to have the touchscreen repaired. If freezing occurs even with the mouse the cause may be one of several. Right-click on the Windows taskbar and select Task Manager. The task Manager box tells you if your processor is working very hard (any reading that continues to hover near 100% indicates some program or process is overworking your system. Task Manager also shows a list of processes and how much cpu % each process is using. Another possibility is that to run everything you want may require more RAM memory. In general, 4GB or RAM is enough, but if you're running a lot of programs/apps at the same time then you may wish to boost your total amount of RAM to 8GB or more.
Sep 25, 2014 | Lenovo IdeaPad Computers & Internet
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Jun 01, 2014 | Computers & Internet
I just recently got a TWC Desktop Error stating UNABLE TO INITIALIZE "PAGE" on my Hp laptop, I canot open any web or internet at all , ever time I tryed it it gives me same error massage, please i am a...
"C:\Program Files\The Weather Channel FW\Desktop Weather\DesktopWeather.exe"
  1. Go to Start, Programs, Accessories, Windows Explorer.
  2. In the left scroll window of Windows Explorer click the + next to My Computer, then click on the + next to C: drive to expand the view.
  3. Scroll down that menu until you find the Program Files Folder.
  4. Double click on the Program Files folder to expand the view.
  5. Scroll down that menu to The Weather Channel FW folder and double click on it to expand the view.
  6. Double click on the Framework folder to display the contents.
  7. Right mouse click on the icon that says "UNWISE.EXE" on the pop-up menu click on COPY.
  8. Go to the tool bar on the window and click the Back button.
  9. In that window right mouse click on the "Desktop Weather" folder and in the pop-up menu click onPASTE.
If it doesn't work donwload this http://www.revouninstaller.com/revo_uninstaller_free_download.html
hope this will help you... Have a Nice Day
Sep 25, 2010 | Microsoft Windows XP Home Edition
Arc mouse - click a window, everything fades to the back
my arc mouse just quit working, Try putting it in the freezer with the USB. Leave it in for a while. when you take it out, it should work. it did for me
Jul 11, 2010 | Microsoft ARC Mouse
I bought a logitechE110 cordless keyboard &mouse 10 monts ago the batterys needed changing this week, now the mouse will only work for a short time with one of the batterys not quite pushed in and no...
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Sep 30, 2009 | Logitech Cordless Desktop EX110
Toshiba Satellite: Keyboard quits working after a while
How about replacing the keyboard? Perhaps, something was spilled on the keyboard in the past.
May 07, 2009 | Toshiba Satellite M45-S265 Notebook
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Looking for a special mouse driver
well.. i am quite sure that no such a thing exist i don't know why you want your mouse pointer jump to the right but there is nothing like that
Sep 14, 2007 | Logitech 967461-0120 Keyboard/Mouse
Gateway GT5220 PC Desktop Logo
522 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
