Question about Kicker 04KX350.2 Car Audio Amplifier
Amp cuts out at certain volume
I have the Kicker kx350.2 hooked up to 2 12in CVR Kickers and I had the bass up one day and then all of a suddent it cut out, now my volume can go up to 9-10ish (not loud at all) until the amp cuts the noise going to the subs. after this happened i realized my gain control was turned up much higher then i had put it meaning someone messed around with my amp but im wondering if this contributed to the problem and if my amp is blown or anything and what i can do to fix it.
  • 113 Answers
Is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
Posted on Aug 08, 2007
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
How to wire 2 12 inch kicker cvr
depending on your amp, you can bridge by connectiung the speakers + to + and - to - and connect to amp using left + and right -, unless otherwise noted on amp. Please give a rating.
Nov 18, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
My subs sound distorted and dont pound right 2 12in cvr kickers and a kingwood 2 channel amp think its not wired right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Mar 09, 2009 | Kicker CVR12 Car Subwoofer
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Kicker 04KX350.2 Car Audio Amplifier Logo
226 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
