Question about Panasonic SC-HT930 System
Dvd surround when powered on display shows int
Main unit will power off but thats all it will do.did something go bad or do i need tray reset manual?
  • joncruzen
    joncruzen Oct 31, 2012
    turns on and off goes to intlize thats where it stays cant eject tray or change to radio.the disc lights 1-5 light up like its coming on.thats all it just sits there says int thats all.
If press eject button,it's showing LOCKED.what can i do?
You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Jan 21, 2015 | home Audio Players & Recorders
Locked dvd tray.
have you tried to unplug the unit from the mains power wait around a minute and power back on if not press the setup button on the remote and reset to factory defaults.
Thanks J
Feb 16, 2008 | Televison & Video
At the last use the DVD player was plpaying and someone' shut it off. It now won't open, and it kept saying no disk found so I thought it was empty. BUT one disk of a series of 3 is missing. I...
You can try 1 of 2 possible options;
1) while the unit is in standby (showing clock only) - on the main unit (not the remote) press [STOP] and [CH UP] button together - for 5 - 10 seconds - this should force the tray to eject any discs that may be in it.
or
2) you can do a hard/power reset - the hard reset - press and hold [POWER ON/OFF] button (again on main unit) for 10 - 15 seconds (this helps if the unit freezes or fails to respond to remote commands).
Other things you can try include; press and hold [CH UP] and [CH DOWN] buttons on main unit (again while unit is in standby) together to reset to factory defaults.
Or you can switch off at the wall, and wait an hour, then switch back on.
Let us assume a disc IS in the tray; try the above suggestions first before going down the expensive and heartbreaking road of either submitting this one to a service centre or buying another unit.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Panasonic DMR-EZ48V stopped working properly. It seems to have frozen up, but resetting it doesn't get it working again. When I reset by pushing the power button for 10 seconds, it flashes HELLO 15...
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
Jan 23, 2011 | Panasonic DMR-EZ48 DVD Recorder
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
Child lock?
press and hold the power button on the unit for 5 to 10 seconds
Jan 22, 2008 | Audio Players & Recorders
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Jan 07, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No power..
See posting regarding hiccupping PSU & faulty diode.
Dec 20, 2007 | Samsung DVD-VR320 DVD Recorder/VCR
Panasonic SC-HT930 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
