Question about Riso RP 3700
T98-526 the drum is locked
Riso rp error T98-526
Posted on Feb 25, 2013
Oki b431 black image drum lock error
The drum lock error is caused by one of two items. Either the drum has seized and will not turn or the drum motor has failed and requires replacing.
Jul 06, 2017 | OKI Office Equipment & Supplies
Minolta cf2001 photocopier, showing error co200.
try a hard reset.
by plugging off the unit from power for one night and then using it again.
Oct 02, 2008 | Minolta Office Equipment & Supplies
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
Konica minolta 7272 drum unit
Check Charging Unit and Drum Orientation position.
Try to insert by manually rotating Drum.
Jul 16, 2017 | Konica Minolta Office Equipment & Supplies
E079
The transfer drum cleaner HP
sensor (PS59) is faulty.
• The transfer locking driver PCB is
faulty.
• The DC driver PCB is faulty.
• The CPU PCB is faulty.
0000 The transfer drum cleaner HP
sensor does not go '1' when
the transfer drum cleaner
locking motor has been kept
on for a specific period of
time.
0001 The transfer drum cleaner HP
sensor does not go '0' when
time.
Jun 20, 2010 | Canon CLC 1120 Color Copier
S 10 1997 Chevy Blazer brake locking up
Common cause is the drums and brake shoes need to be replaced. When there no longer within the the specification for the brakes to work properly, the self adjusters will over adjust the brake shoes and you'll have the feeling of the rear drum brakes lock up as the shoes will bind up along the drums. Replace both Shoes and Drums and this can be done on your own will common tools and a simple brake spring tool that you can pick up at Auto Zone or Parts Source and both can give you the step by step instructions to replacing the rear brake system. Good luck and be safe.
Feb 21, 2010 | 1997 Chevrolet Blazer
How do i reset the brother dr350 drum
If you have already replaced the drum - only do steps 1, 2, 3, 7 and 8.
1. Make sure that the printer is turned on and the Drum LED is blinking. Open the front cover of the printer.
2. Press and hold the GO button for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release the GO button.
3. Pull out the drum unit and toner cartridge assembly.
4. Push down the blue lock lever and take the toner cartridge out of the drum unit.
5. Unpack new drum unit.
6. Put the toner cartrisge firmly into the new drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
7. Put the drum unit and toner cartridge assembly in the printer.
8. Close the front cover.
Jan 29, 2010 | Brother HL-2040 Laser Printer
Metal fatigue has messed up the driver side door lock latch
remove door panel,remove plastic nylon, You will see inside part of lock drum, with a center arm screwed in, remove arm carefully and look for a "U" Grooved,lock around bottom attaching drum to panel clipped from the top, pride up with flat screw driver and lock drum will fall out, get new drum from junk yard or better with dealer
Jan 25, 2009 | 1994 Chrysler Town & Country
Rear brakes locking up with slight touch of brake pedal.
Most of the time with the rear brakes locking up the brake drums are warpped. If you remove the rear brake drums and take them to almost any auto parts store (Napa, Checkers ect.) they will turn the drums for about $10 a piece.
After you have the drums turned you will need to readjust the rear brakes.
Aug 29, 2008 | 1994 Chevrolet Corsica
NEW DRUM
joe, to replace the drum, you need to remove the cover from the front of the drum unit it has three locking tabs,one removed,take main charger/grid unit out,located on the top of drum unit,two screws one on each end. the drum is held in with a cam lock shaft located on the front of the drum unit,turn it couter clockwise,your drum can now be removed,it's recomended that you replace the cleaning blade also,two scews. you'll have to coat the new drum with toner and manually turn it against the new cleanig blade,if you dont the blade may flip and ruin your new drum.reassemble
May 01, 2008 | Toshiba e-Studio162D Copier
Riso RP 3700 Logo
267 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
