Question about Toshiba 36AFX61 36" TV
Vertical output problem
I have a horiz.line about 1/4" thick across my screen, it is in color and you can tell the picture is moving, sound works fine and you can change channels, in the past this has happened and a couple of whacks on the back and the picture would come back, the tv is five years old.
  • robert oneill May 19, 2007
    the solder joints look fine should i resolder them anyway, and josh you are right it is part no. la7846n
    Scholar:
  • 77 Answers
You probably just need to resolder the vertical output IC. It will be mounted on a heat sinc. probably 7-10 pins. Part number may start with "LA" like LA7845 or similar, there are others though. You will probably see the rings around the solder joints on the bottom of the board. Good Luck
Posted on May 17, 2007
Projection TV no picture flashing horiz arcs across top of screen sound okay
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting.
This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
Jul 24, 2014 | Toshiba Televison & Video
I have 3 black lines running across the centre of the screen of my compaq laptop,2 thick,1 thin.
if you move the screen back and forth does it change any? It sounds like either there is a connector not making good connection or your screen is bad.
Sep 10, 2009 | Compaq Computers & Internet
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Horizontal Line Across the screen
Your Zen got bashed. or at least the screen suffered some violent movement and shifted on its moorings. To make it simple... all around the perimeter of the LCD screen, there are electrical contacts for HORIZ and VERT signals which come thru tiny ribbon cable (looks like copper colored ribbon but actually is flat mylar with wire laminations inside) anyway, these are either socketed, soldered or have pressure contacts which make the connection and give you colors in the right places. The connector for an entire HORIZ row came loose, got bent or broke. The only fix is to locate it and either resolder it (difficult without a 'needlepoint soldering iron), reshape that single contact so the right part of the display (HORIZ connection cable) touches its pad again, or replace the display,, socket, or its cabling. I have one with bad HDD but everything else is OK (Display too) which I can sell you cheap. All you'd have to do is pull your HDD, install it in my old Zen, and go.
PM me if you are interested: somethingscrooked@uku.co.uk.
Nov 17, 2008 | Creative Labs Zen Digital Media Player
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Toshiba 36AFX61 36" TV Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
