Question about Food Mixers
Presto pm 20 mixer lever broken - Food Mixers
My handle on KitchenAid KT26S1X Epicurean Stand Mixer is jammed and won't lift or lower bowl. Can you advise?
I'm not familiar with that particular model but the common cause of that fault on the ones I do work on is a broken or cracked lift lever inside the stand. You need to remove the stand from the motor housing. 4 screws going up through the stand into the underside of the motor casing at the back. That will expose the lift lever mechanism for you to identify the problem.
Jul 14, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
How do I get a manual
Hi Jeff,
I was able to locate the spec sheet for this product:
http://mvpgroupcorp.com/details.php?cat=7&id=119
You may have to contact the manufacturer to explain which parts you want to order. I was only able to find service information for their JetTech product line.
Jun 09, 2014 | Presto by MVP PM-30 Presto - Mixer, Food"
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 15, 2013 | KitchenAid K45SS Classic Stand Mixer
EM 20 Dito Dean stand mixer does not hold speed
could you make a small spacer to put behind the screws so the cover would fit again .
May 23, 2010 | Dito Dean Food Prep 746 Watts EM-20 Stand...
Replacing the lever latch
Look at the parts diagram in the following:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
and in particular:
9 24452 Latch, Link & Lever
Hope that helps you figure out where the parts go.
Apr 07, 2010 | KitchenAid Classic Stand Mixer
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Jul 23, 2009 | KitchenAid KP26M1X Stand Mixer
The lever to start the machine the one that moves to the right to select the speeds won't move
Are you sure the bowl is locked into place? If it is, also check the safety mechanism that the bowl moves in order for the mixer to turn on to ensure that it isn't broken and is moving as the mixer won't turn on if the bowl isn't turning off this safety feature which is probably broken if the mixer start arm won't move.
Benjamin
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My 20 qt. mixer has no power in speed #1.
Hi All. Since the original poster has not responded to my request for ML and spec. #'s, I'll offer a solution based on a spec.# 3943 for anyone with the same problem. This is an older model A200 with a solid aluminum gearshift lever.
Stop using the mixer!!!
The slow speed gear (1st. gear) is engaged by a "diving key". Over time this key can wear to the point of failure, or break entirely and will no longer engage. This failure only affects the first gear, allowing the second and third gears to function properly. If you can stop the mixer attachment by hand while in 1st. gear, then you have the above problem. The unit must be serviced. If the key has been sheared there is the potential for a broken piece of this key to get into the trans. grease and cause further damage to the mixer. For a Hobart Tech., this is relatively easy to repair as a minimum number of parts need to be removed in order to expose the diving key.
Call your local Hobart office to schedule a repair. If you've never done any repairs on this model, do not tackle this project by yourself. I you have some experience with this model goto the hobartservice.com website, register for free and then download the parts list. Ensure that you have the list for the 3493 spec.
If anyone has been assisted by this solution, please rate it. ricardok45
Mar 17, 2009 | Hobart A200 Stand Mixer
Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Aug 04, 2008 | Wolfgang Puck Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
