How to take apart a nibco #52 valve - Televison & Video
What does error 52 mean
52. (00110100) Phase 5 and 6 Eco - Diverter Top-up Fault
More than 6 attempts to top-up the water level in the bowl, this then signifies the
valve has not closed and is diverting to drain, or the top-up was not increasing quick
enough suggesting the valve has a blockage and is also draining.
Primary Source: Diverter valve
Action: Remove the diverter valve and check for blockages or broken hinge
mechanism.
Secondary Source: Wax Solenoid
Action:
Check the resistance of the wax solenoid, also look for corrosion on the terminals
(greenie deposit) resistance range will be between 0.7k? and 2.5k?. Values are
dependant on ambient temp and when the valve was last actuated. Anything
outside of these values should be automatically replaced.
Aug 03, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
Cant get soder to hold on copper pipe soder flakes away doesnt stick
make sure joints are clean and sanded,flux-use mapp gas in torch burns hotter then propane,needed for 95/5 solder preheat up and down pipe for a few inches then do joints,keep you torch moving around joints it'llget a silver color then its ready.Don't get to hot or it will burn up flux.ps no water in the line or you'll never get it,cleaning pipe and fitting is most important
Jan 28, 2011 | Nibco Reducing Tee Copper X Copper X...
Error code 52. what does this mean?
Code 52: Is a diverter valve fault
Action: Remove the diverter valve and check for blockages or a broken hinge mechanism.
Nov 10, 2010 | Fisher and Paykel IWL12 Top Load Washer
Knock on front left suspension v70 52 plate
usual cause is the anti roll bar drop link that is worn easy to replace
Nov 23, 2009 | 2001 Volvo S60
Fault 52
Code 52 is a loss of water during recirculation cycle. Possibly due to a faulty divertor valve. Check to see if water is circulating back into bowl & no water escaping out of the drain hose. May also be caused by a faulty motor controller.
Jan 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
