Question about Logitech Cordless TrackMan Wheel 904346-0403 Trackball
Computer can't find mouse...
If i move the trackball as the computer is booting up, it finds the mouse ok. But if i walk away while booting, when i come back the mouse don't work. and i haven't had much sucess with the  little "connect" button. Does anyone know just when the computer LOOKS for the mouse?  Any help would be appriciated, Ken
  • kenbenson Jan 04, 2009
    I am on a Mac iBook G4, i'm not sure how valid your info is, but thanks for the input... Ken
  • 741 Answers
Well your problem sounds like a unique one, however, I can tell you exactly when you're computer looks at your mouse. When you push the power button the computer goes into the POST mode (Power-On-Self-Test). This is a good minute before you see the Windows login. During POST the processor is detected, how much memory, what hardware is recognized and whether BIOS has Plug n Play. After POST the boot process starts, during the boot process there is a file called NTDETECT.COM, it is used to detect any hardware that is installed and adds that information into the Registry..there are some other files but it does not pertain to your problem. After boot is when you hear the beep on your computer, the one beep is saying all is well and ready for the operating system. So it sounds like your mouse is not being detected either during POST or when NTDETECT.COM runs during POST. Here are some steps you can take: First you must replace the mouse to test its electronics. If the replacement mouse works, the original mouse was defective. If the replacement mouse does not work then the original mouse's electronics are good. In this case the mouse driver or the port hardware is the problem. Find mouse in Device manager, uninstall driver, then reboot see if the Plug and Play picks it up. Update and re-install drivers. If the drivers don't work then its the motherboard, go back to the PS/2 mouse. Hope this helps. Let me know how it goes.
Posted on Jan 04, 2009
  • Randall  Trahan
    Randall Trahan Jan 04, 2009
    Ok you didn't state that in your problem but that's ok, if you take the troubleshooting part at: "Here are some steps you can take"..it does not matter what operating system it is; it will narrow it down to mouse or mouse driver.
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
My trackball mouse will only move the cursor one direction
remove the ball ring take the ball out and visually check to see it alot of link has accumulated on the rubber wheel surface, if it has gently use a pair of tweezers or a q-tip w/alcohol to clean the surface of the directional wheels.
Dec 05, 2009 | Fellowes Micro Trac 99928EA Mouse
Blackberry trackball wont work
I have the Blackberry Tour.......I work in all kinds of environments....so I get dust, dirt, and debris in my trackball......every 3-4 weeks I cannot move the trackball.......all you gotta do is get AIR DUSTER, the same you use for your computer keyboard etc. and keep it about 3-4 inches away and spray the air at your trackball and move it around......just keep spraying it for about 1-2 seconds at a time and move the ball around after every spray and you are good to go!!!!!
Nov 09, 2009 | Lands Phones
Kensington mac os x driver doesn't work
Try Step A
Unplugging it and re plugging it back in
Or if you have another mouse do step A then move the curser with the mouse and now the trackball will work
Frustrating Isn't it !
Nov 07, 2009 | Kensington Expert Mouse Trackball
My Microsoft trackball optical 1.0 ps2/usb PN X05-87475 poduct id 52240-576- 3714006-00000 has quit moving the curser on screen. other buttons seem to work ok. Is it fixable.
There is a seller on ebay - Trackballs R Us - that fixes these kinds of problems. Has quite a reputation for fixing Explorer and Optical trackballs and guarantees the work.
Sep 26, 2009 | Microsoft Computers & Internet
SetPoint messed up my Synaptics touchpad.
Go to Start > Run > type "msconfig" (without quotes) > OK > tab Startup, find entry C:\WINDOWS\KHALMNPR.EXE and untick it. Click OK and reset your computer. After logging on, open Control Panel and restore your mouse settings like you had it before installing SetPoint.
You can also try this:
In SetPoint you can go to the Mouse Game Settings (the chess piece), from there, click "Enabled" for Game detection, then click "OS Implementation" under Speed and Acceleration.
Hope that helps. Kindly rate the solution if it helped.
Cheers!
IrishDruid
Jun 20, 2009 | Logitech Marble Mouse Trackball
After accidently unplugging the mouse's usb reciever, the pointer froze on the monitor screen.
Try plugging in a standard mouse and changing the settings to it, Then re-boot. Once booted try plugging the TrackMan Wheel back in and changing the mouse settings back to it and re-boot again. Let me know what that does for ya.
May 24, 2009 | Logitech Cordless TrackMan Wheel...
Logitech Marble Mouse driver/setpoint messed up my synaptics touchpad on my laptop...can't fix this!
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Oct 24, 2008 | Logitech Marble Mouse Trackball
Logitec trackball
I have a logitec trackball marble mouse usb for one computer and ps2 socket for another, both have 5 screws. To find the fifth you have to feel about on the sticker on the back and poke a hole in it.
Linear
Jan 15, 2008 | Logitech Marble Mouse Trackball
Logitech Cordless TrackMan Wheel 904346-0403 Trackball Logo
851 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
