Question about Sony Televison & Video
Sony Rm-GA010 Remote Control: Some buttons work perfectly others do not function
I have a sony RM-GA010 and some button work perfectly fine like the channel and menu buttons while others like volume and input buttons do not seem to functionat all. How can I fix all buttons to work?
  • Zak Chehab Oct 31, 2012
    Thanks Trevor used aluminim foil and worked perfectly!! Appreciate it.
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
ricomun
  • 24 Answers
SOURCE: SONY Remote Control - some buttons do not work.
Usually this means the conductive contact on the back of the rubber pad has worn down and cannot connect the circuits on the remote controls main board. There are several ways to fix this.
#1 Find some conductive adhesive or paint and carefully paint the back of the button tab ( let dry completely)
#2 Rear window defogger kits are available at most reputable auto parts shops and contain a paintable adhesive which you can apply to the back of the remote control button.
#3 try super gluing a small piece of aluminum foil to the back of the button tab.
I have used all 3 and they all work good.
Posted on Jul 02, 2009
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
  • 19 Answers
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
SOURCE: TV remote RM-ED002 for main TV works fine except volume
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Posted on Nov 03, 2009
What's the difference between sony rm-yd028 or rm-yd065?
To most Sony remote controls, P+ / P_ & Vol+ & Vol -- ; buttons will work, except for other buttons will work. The difference between the Sony remote controls you mentioned here too will differ to these function. http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Televison & Video
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
I have sony tv rm-GA010 controller.for lcd tv. but
Hi, you can order a new RRMCGA759WJSA from Replacement Remotes. or you can order the keypad repair kit from replacement remotes to fix your keypad problem. You need the solution that is sold in the kit to fix the rubber keypad for those buttons.
Nov 01, 2013 | Sharp GA759WJSA Remote Control...
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
I have a rm-p311 remote can it be programed to run a newer unit
Sony remotes keep the same codes for all there tvs. It will run older as well as the newest tvs. Hope this helps.
May 10, 2011 | Sony RM-P311 Remote Control
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Code no.?
This information is to search for any code using the SONY RM-VL990T Universal remote:
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
May 09, 2009 | Sony RM-VL900 Remote Control
Sony Rm-v202 remote the tv/video doesn't work
I need the code for operating an emerson television
Nov 19, 2007 | Sony RMT-V202 Remote Control
Televison & Video Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
