Question about Craig Televison & Video
I droped my tv and now I can only get sound
The tv turns on but the picture is just a bunch of colors
    Top Expert:
  • Craig Master
  • 74,377 Answers
Check whether CRT has been damaged or not.
Posted on Nov 01, 2012
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I HAVE A TOSHIBA 37AV502U, THE PROBLEM I'M HAVING IS THAT THE COLOR ON THE PICTURE IS WRONG, IT'S A BIT HARD TO EXPLAIN BUT IT LOOKS LIKE THE PICTURE WAS TYE-DYED OR SOMETHING, YOU CAN SEE THE CABLE...
IF THE MENU LOOKS CORRECT THEN IT WILL BE A MAIN BOARD FAILURE IF THE MENU LOOKS GOOD THEN IT COULD BE T-CON BOARD FAILURE. CHECK ALL CONNECTIONS BEFORE AND AFTER THE PARTS ARE REPLACED.
Dec 17, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
My Samsung DLP hln567w tv has NO picture on all
If the Lamp ignites and stays lit, but screen is completely black, not even the on screen display, then it is likely a bad DMD board.
If the lamp ignites and then turns off after a couple seconds then it is likely the color wheel is seized.
If the lamp never fires, but the TV clicks a bunch of times, then it could be a bad Ballast or the Lamp itself.
Sep 18, 2009 | Samsung DLP HL-P5663W 56" TV
Philips HD Projection TV just too dark (No Luminance)
sounds like the coolant needs to be replaced in the CRts as that will give you a very dark and dull colored picture. The phillips CRT coolant replacement kit at the following link contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 22, 2009 | Televison & Video
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
Toshiba 50HP16
"Popped"? That sounds like a serious issue that is going to require a warranty repair or a professional TV repair person to address.
May 01, 2008 | Toshiba 50HP81 50 in. Plasma Television
No picture
try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
Apr 22, 2008 | JVC AV-32260 32" TV
Droped my tv
maybe you have broken picture tube! at the CRT neck tube! or maybe you have broken crack board! all you have to do is to open the TV to confirm if damagen the tubes! or the main board!
Oct 14, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
Aug 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
